Old 10-22-2020, 07:36 PM   #1
totto
totto's Avatar
Default Horn condenser
I have a 1934 horn with a condenser and horn is not working; would like to replace the condenser. My question(s): 1.) what condenser do I replace it with? 2.) The original condenser is a 2 wire condenser- can I find a 2 wire condenser and 3.)which wire goes where when replacing.
Thanks
Henry
totto is offline   Reply With Quote
Old 10-22-2020, 09:47 PM   #2
koates
Default Re: Horn condenser
Your Sparton horn condenser is .2mfd 400 volt. Look them up on ebay,very cheap. They have a wire out of each end. The condenser is connected across the horn contacts or in other words each condenser wire goes to each horn contact, soldered onto a tab. Easy to fit. The horn requires a condenser to work nicely. Regards, Kevin.
koates is offline   Reply With Quote
Old 10-23-2020, 08:27 PM   #3
totto
totto's Avatar
Kevin:
THANKS for your input!! Will follow your directions.
Henry
