02-27-2020, 11:44 AM | #21 |
Re: 1949 Ford 8n Tractor
Heres my NAPA tractor cheat sheet I printed it out and it hangs in my local NAPA.
NAPA Ford 9N,2N,8N Tractor cheat sheet Front Mount distributor... Points: NAPA #CS35 or Standard Ignition Blue Streak #FD-6769X (Premium) Condensor: NAPA #FA200 or Standard Ignition #FD-71 Rotor: NAPA #FA300 or Standard Ignition #FD-104 Distributor Cap: NAPA #FA350 or Standard Ignition #FD-126 6 volt coil IC7 6 volt voltage regulator VR950 GL-1 90w Mineral Oil Napa Part# 65-205 8N Oil Filter Napa# FIL-1010 or Wix #51010 Cyclone top mounted pre-cleaner gasket Napa Victory# G26410 or Fel-Pro# 11528 Steering Sector Oil Seals NAPA Part Number – 11055 Sediment bowl neoprene gaskets NAPA/Balkamp "O-ring" p/n 730-9506 Marvel Shebler Carb. Rebuild Kit NAPA KIT #2-1401 8N Head Gasket NAPA# NGA-1950 Welch (“Freeze”) plugs, 1-13/16” NAPA 219-1021 4 brass nuts for exhaust manifold: 7/16-20 x 5/8, NAPA part number STN104X. 4 brass nuts for exhaust manifold: 7/16-20 x 5/8, pack of 10 from Fastenal p/n 1175115 4 studs for exhaust manifold: 1-5/8 long 7/16-14. NAPA part number for a 1 ¾” stud (Handi-Pack item) is RFD 86644. (stud is longer than OEM so make sure it does not bottom out in the block) The 2” stud is p/n 86632 which can also be used. Fel Pro Gaskets for N’s, Head Gasket 7277B Head Set HS7277B Full Set FS7277B Manifold Set, Intake & Exhaust MS8782B Oil Pan Set OS 2916D Valve Cover Set VS2976 Timing Cover Set TCS 2921 Carb Mounting 8783 SEALS Chicago Rawhide/SKF part numbers Governor seal # 3683 PTO shaft seal # 16189 PTO shaft seal Speedi-Sleeve # 99162 Transmission input shaft seal # 13568 Transmission input shaft seal Speedi-Sleeve #99138 Outer Rear Wheel Seal 8N though S.N. 486752, # 24986 Outer Rear Wheel Seal 8N from S.N. 486753, # 27426 Inner rear Wheel Seal 8N # 19831 BEARINGS Front Wheel Inner, # BR15118 Cone, # 15250-X Cup Front Wheel Outer, # BR09074 Cone, #BR09196 Cup Clutch Pilot Bearing, # 6203-ZJ Complete throwout bearing/carrier assembly, # N1425 Throwout bearing only, # N1087 Throwout bearing only, regreasable, # N1167 Differential side bearings, # BR3984 cone, # BR3920 cup Pinion bearing, front and rear, # BR53176 cone, # BR53375 cup Rear differential pilot bearing (straight roller bearing) # RS5305-W Transmission countershaft bearings, # BR25877 cone, # BR25820 cup Inner bearing, CNH 86609936 Timken 15118 Inner race CNH 86577043 Timken 15250X Outer Bearing CNH 86576860 Timken 09074 Outer race CNH 72063 Timken 09196 Good place to get parts and info https://www.just8ns.com/ Last edited by corvette8n; 02-28-2020 at 06:59 AM. Reason: Added link |
02-27-2020, 01:10 PM | #22 |
Please be more specific - which "Ford Gray"? And are you restoring a 9N/2N or 8N? If a 9N/2N, are you going back to the original "battleship"/dark grey monochorme look used from '39-'47, or the "redbelly" '48-'50s 8N look that dealers loved to use to make the older tractors cosmetically look like an 8N, which used an olive-grey on the tin and Vermillion Red on the engine/running gear? Plus there's different grays used from '57-'62 and '63-up, with the '60s Grey being almost whitish. I have Ford M-#'s for all of them but won't be able to post until tonight.
Alan H. Tast AIA, LEED AP BD+C Technical Director/Past President-Editor-Publications Director, Vintage Thunderbird Club Int'l. (VTCI) http://www.vintagethunderbirdclub.net Author, "Thunderbird 1955-1966" & "Thunderbird 50 Years" 35+ year member, Crown Victoria Ass'n. Last edited by alt63bird; 02-27-2020 at 01:16 PM. |
02-27-2020, 02:53 PM | #23 |
For wheels (rims and centers) and wheel weights, I used a spay paint color that matches, pretty well. The color is pewter.
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
02-27-2020, 04:22 PM | #24 |
I have a 2N with an 8BA in it. See my avatar. It is an Awesome Henry conversion.
02-27-2020, 04:54 PM | #25 |
Actually near me its French Lake Auto Parts.
02-27-2020, 11:44 PM | #26 |
GRAY Paints: 9N-2N (DARK) GRAY: M-1778-H, M-13243 TISCO - TP230 Ford Dark Gray Martin-Senour - 6019 Ford-Ferguson Gray -available at NAPA NAPA - 991 21200 Gray Cote-All - AZ-0405 Tool Gray (made by Diamomd Vogel Paints, Orange City, Iowa) NAPA - 99L3732 8N GRAY (Olive Gray): M-13243 PPG DELSTAR - DAR 31657 (OLD DITZLER NUMBER) TISCO - TP240LF FORD MEDIUM GRAY CNH - NEW HOLLAND GRAY 8N RED: M-2822 TISCO - VERMILLION TISCO - TP310LF FORD RED TISCO - TP480LF NH RED TISCO - TP110LF IH RED PPG OMNI AU (MTK) - 3794; ALT OEM CODE: 81, WA8774, WA784 - GM BRIGHT RED DIAMOND VOGEL INDUSTRIAL - 141959 RED CNH - NEW HOLLAND RED RUSTOLEUM - SUNRISE RED PPG-Ditzler - DQE-70801 SILVER: M-1J-23 - Ford Argent Silver (Original Rims were Silver Cadmium Plated) CASE/IH SILVER ARGENT. Used on rear hat rims. RUSTOLEUM METALLIC SILVER PPG-Ditzler - DEE-45 Argent Silver/Aluminum Metallic BLACK: For N-Series Pan Seats- TISCO - TP550LF GLOSS BLACK AGCO - GLOSS or Semi-Gloss Black Enamel Radiator: Use a semi-gloss black heat-resistant paint. Local radiator shops carry it. ...and from YesterdaysTractors.com https://forums.yesterdaystractors.co....php?t=1358655 Here are some OEM equivalent paint codes that may help Ford Tractors 1948-1957 Grey (Medium) Ford Paint Code: M 13243 Tisco: TP240 PPG: 32675 Centauri: 250202 Van Sickle: 457 Martin-Senour: M2J957 Red (Vermillion) Ford Paint Code: M 2822 Tisco: TP480 PPG: 70075 Van Sickle: 480 You can also go here: https://paintref.com/cgi-bin/colorco...&model=Tractor
Alan H. Tast AIA, LEED AP BD+C Technical Director/Past President-Editor-Publications Director, Vintage Thunderbird Club Int'l. (VTCI) http://www.vintagethunderbirdclub.net Author, "Thunderbird 1955-1966" & "Thunderbird 50 Years" 35+ year member, Crown Victoria Ass'n. |
02-28-2020, 05:12 AM | #27 |
Thanks everybody pretty sure its the olive gray M 13243 I'm after sam
03-01-2020, 08:28 PM | #28 |
https://www.smokstak.com/ Doesn't suck.
Most of the ford tractor engine and knowledge is relevant here also. . |
03-02-2020, 10:51 AM | #29 |
They used the 9N tractor engine in the 1941 pickups for a bit but it didn't pan out well.
03-02-2020, 01:09 PM | #30 |
www.n-news.com might be a source too.
03-09-2020, 06:42 AM | #31 |
Bought some great parts from Dennis Carpenter and the quality is really good. Went online to a couple places and good response for help.
Bought paint also from Dennis and the color is almost perfect from the original. Good stuff ! Thx....Mike |
03-09-2020, 06:35 PM | #32 |
Also in the Ford GP jeeps, along with the Model A transmission. That combo didn't make it to the GPW.
I dig coal, which provides motivation for EVs. |
