03-30-2017, 03:22 PM | #21 |
Re: 337 Flathead
Engine looks awesome!
The upside down picture is due to the gyroscope in the ipad and the fact that you are standing above the object looking down. The gyroscope has not been set to horizon when picking up the ipad. Be sure to look at the picture of the camera on the screen before you hit the button to make sure the ipad is in the right orientation when you pick it up off the table. You can see that little camera rotate orientation as you rotate your ipad. Before taking a standing picture of the floor, first point the ipad at the wall to orient the ipad to what is up and then tilt down. That should fix the problem with up-side-down pics.
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
03-30-2017, 04:08 PM | #22 |
Re: 337 Flathead
Beautiful engine. Inspires me to go out in garage and work on mine
Sent from my LG-K371 using Tapatalk |
04-01-2017, 03:06 PM | #23 |
Re: 337 Flathead
Wanted to go and put the oil pan and sump back on, but it's snowing and cold! Not an April fools day joke either.
04-02-2017, 06:07 AM | #24 |
Re: 337 Flathead
I had someone ask about my color choice, well it's certainly not stock. First what color was it supposed to be? The block was a dark red. I believe that was correct for a Ford motor. However, the heads and intake were later model ford blue. And that seems reasonable as the motor had been rebuilt one time. When I pulled the oil pan to clean, paint, and reseal I could see the numbers punched into the rods. Now a Lincoln engine would have been a light Lincoln green.
Now what I ended up with was "Red Annodized". I primed the block which was light gray then when I started painting the red, it went on in a strange way. I read the can between the 2nd and 3rd coats (shoulda done that first) and it says to spray over chrome! Well it was kinda too late for that. There was only one thing to do.....keep painting. Anyhow, I'm actually happy it worked out this way. I like the dark maroon end result. The gray on the goosenecks and oil filter housing are "new ford gray". |
04-02-2017, 04:15 PM | #25 |
Re: 337 Flathead
Pan is on.
04-13-2017, 03:56 PM | #26 |
Re: 337 Flathead
Here's where the video is, can't seem to post here... https://youtu.be/obKvw8u7ZUc |
04-13-2017, 05:29 PM | #27 |
Re: 337 Flathead
Sounds pretty good, but my eyes hurt now
04-13-2017, 05:58 PM | #28 |
Re: 337 Flathead
I just think this engine is going to work better in this orientation!
04-13-2017, 07:00 PM | #29 |
Re: 337 Flathead
Ha, I agree! Poor computer skills on my part. Thank You!
04-13-2017, 07:04 PM | #30 |
Re: 337 Flathead
Just trying to keep the oil from running out.
04-14-2017, 04:36 PM | #31 |
Re: 337 Flathead
04-14-2017, 05:06 PM | #32 |
Re: 337 Flathead
I thought the 337 Lincolns had hydraulic lifters. Not sure, but if they do, I agree it's pretty noisy for hydraulics.
Sal |
04-14-2017, 05:12 PM | #33 |
Re: 337 Flathead
This one is definitely not hydraulic lifters. But there are two sets of valve lash settings plus a third for the hydraulic lifters! I guess I'll try the "tighter" settings.
08-14-2017, 06:00 PM | #34 |
Re: 337 Flathead
Got the lifter adjusted and also replaced one bad valve spring. Runs even better now, and with no lifter noise.
https://youtu.be/98QTuP1tTic "Are you ignorant or apathetic? I don't know and I don't care." |
08-19-2017, 09:08 AM | #35 |
Re: 337 Flathead
That sounds a lot better, runs nicely now.
I just noticed the generator stand in the photo of your first post. Did that go to some sort of extra large generator? I like old large capacity generators. |
08-21-2017, 05:17 AM | #36 |
Re: 337 Flathead
The generator was missing when I got the engine. I checked the part number for an original generator for the big trucks. It is different than say an 8ba flathead. However I had an 8ba generator here and tried it. It fit fine and I could have used it. I have kept the old generator stand and can reinstall it if I choose to. The alternator was one I had and the alternator bracket fits an 8 ba flathead.
