02-17-2016, 06:03 PM | #1 |
Marvel Mystery Oil increases engine HP?
I have heard many stories about adding Marvel Mystery Oil to you oil and gas can increase the performance of an engine. Increase HP?
Has anyone experienced this effect? |
02-17-2016, 06:13 PM | #2 |
Re: Marvel Mystery Oil increases engine HP?
Is that what's called "cure all in a can"? Mystery Oil is a good product but I don't think it will add any more HP to your engine. I can see it increasing performance by simply freeing everything up from sludge to carbon.
www.dickshotrodcarbs.com |
02-17-2016, 06:14 PM | #3 |
It's main use is to lubricate the valves, etc. I use it every time I put gas in...........glug, glug, glug.
Paul in CT |
02-17-2016, 06:15 PM | #4 |
yea it may free things up and restore some lost oomph.
02-17-2016, 06:21 PM | #5 |
I used MMM in my 41 Packard. It seemed to help get rid of vapor lock. The fuel line ran pretty close to that long exhaust manifold.
02-17-2016, 06:29 PM | #6 |
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
02-17-2016, 06:34 PM | #7 |
I bought a quart of MMO several years ago. Does that count?
02-18-2016, 08:35 AM | #8 |
Unbelievable that MMM is a power adder without a dyno test.
I have not seen any test evidence that indicates MMM has value as a gasoline or engine oil additive. Can anyone link us to a test data?
Bob Bidonde |
02-18-2016, 11:01 AM | #9 |
The data is kept in a safe along with the 250 MPG carb we all have heard about.
1928 Model A Phaeton Knoxville, TN 37914 |
02-18-2016, 11:13 AM | #10 |
Nothing on the label about HP so your answer is No Increase in Hp. Lubrication yes Good for Valves.
www.whidbeymodelaclub.com |
02-18-2016, 11:14 AM | #11 |
Now Bob. IF there was any proof it would no longer be a "Mystery".
02-18-2016, 11:26 AM | #12 |
back in the 60's we used it to quiet noisy hyd valve lifters, to good effect, then looking and feeling it, it seemed similar to ATF which did about the same thing for less money. I'm sure that it has more additives in it that help things. If it helps the rings from getting gummed up it would add some compression and power, but without dyno results there is no proof.
02-18-2016, 11:31 AM | #13 |
Just like ALL forum sites;Google it and you will have all the answers you need and then some and then you will really be confused.I use it and it "Does help Lubrication due only to the dry ethonal gas"!
02-18-2016, 11:39 AM | #14 |
For those that run MMO.
What's the mixture ratio that you use? I run only pure gas, and have a full tank right now.
02-18-2016, 11:42 AM | #15 |
I run about 3-4 oz in each fresh tank. More of a glug glug eyeball measuring method not officially measuring it
Blackwall Panthers Nor Cal chapter |
02-18-2016, 11:46 AM | #16 |
I buy MMO by the gallon at Wally World. I don't use any formula when mixing it with the gas, just pour in what looks to be a good amount. Each time I add non-ethanol gas to the "A".
Bob-A |
02-18-2016, 12:04 PM | #17 |
Reminds me of the Geritol and Carters pills ads from the '50s
02-18-2016, 12:46 PM | #18 |
Pure Snake Oil !!!
Gullible buyers think it will preserve their engine forever, cure any ailments, etc. Waste of money for sure. A well built and tuned engine is not going to evolve from this "mystery in a bottle". |
02-18-2016, 01:34 PM | #19 |
Reduces pre-ignition problems if that state exists. Lowers volatility of fuel. Preserves fuel freshness, especially in alcohol fuels. Helps retard rust from stagnant alcohol laced fuels. Decreases sludge buildup in vehicles that never see adequate burn off temperatures.
02-18-2016, 02:09 PM | #20 |
For a ill running engine not a sick engine, using 4oz/ 10 gal gas will help smooth things
This would be the only increase in HP, from running sick to running smooth IMHO |
