Old 05-29-2020, 07:57 AM   #1
Don
Don's Avatar
Default Wheel bearing grease
I have 3 or four tubs of grease for disc and and drum bearings,is there something special for the rear bearings ,think the fronts are like any other wheel bearing,just a good grease.???
DON P
Don is offline   Reply With Quote
Old 05-29-2020, 08:04 AM   #2
19Fordy
19Fordy's Avatar
Default Re: Wheel bearing grease
STA LUBE 3131 is the grease to use.
https://www.qualitymill.com/2999089/...e%C2%AE-SL3131
Old 05-29-2020, 09:03 AM   #3
flatheadmurre
flatheadmurre's Avatar
The rollers take a heavy duty grease...same as a heavy truck...look for NLGI 2.5 specification.
Old 05-29-2020, 09:42 AM   #4
philipswanson
Mobil I Synthetic. Also used on big trucks and motorhomes.
philipswanson is offline   Reply With Quote
Old 05-29-2020, 10:16 AM   #5
Will D
Will D's Avatar
I second the STA LUBE 3131 for the rear roller bearings. It is a sodium based fiber grease. I use Lucas red and tacky for the front only because the sta lube is very hard to get where I live so I save it for the rear, but is readily available in your area.
Will D is offline   Reply With Quote
Old 05-29-2020, 10:16 AM   #6
KiWinUS
KiWinUS's Avatar
We have used Mobil synthetic first 220 & now 460 in our race cars for 30 plus years. Consequently I have used it in every road car/ truck of my own for that long also. It is an amazing product & the only grease to use in my opinion. The heat & load of our race cars for 500 plus miles with very little grease used in our hubs.
Old 05-29-2020, 10:20 AM   #7
Tim Ayers
Tony:
Thank you for this. Curious why you moved up to the heavier (?? I'm assuming) 460 from 220?
Old 05-29-2020, 10:35 AM   #8
KiWinUS
KiWinUS's Avatar
Tim recommended to us by Mobil for higher loads every other aspect the same.
Old 05-29-2020, 10:36 AM   #9
Tim Ayers
Cool. Good to know.
Old 05-29-2020, 11:13 AM   #10
rotorwrench
rotorwrench's Avatar
Grease and oil are those things which will render many different answers when questions come up. The old drum brake sodium soap grease will work just fine. The more modern aluminum soap grease for rotors will also work. They take high temps very well.
rotorwrench is online now   Reply With Quote
Old 05-29-2020, 06:06 PM   #11
Don
Don's Avatar
Thanks ,I’ll see if I can find locally!
DON P
Old 05-30-2020, 03:18 PM   #12
hotrodart
hotrodart's Avatar
i have used synthetic grease for 30+ years.....over 150K miles combined......never had a bearing fail.
hotrodart is offline   Reply With Quote
Old 05-30-2020, 05:52 PM   #13
FL&WVMIKE
FL&WVMIKE's Avatar
Grease Test by Project Farm.
All greases are NOT the same. Very interesting to see how they compare.
https://www.youtube.com/watch?v=mMmSQSjraSE&t
Mike Jr. here. I get on here every few months to check messages, and look through his almost 500 saved messages for information on the '29 and '34 I still have. A lot of very nice people on here. He truly enjoyed Ford Barn.
FL&WVMIKE is offline   Reply With Quote
Old 05-30-2020, 07:59 PM   #14
1948F-1Pickup
1948F-1Pickup's Avatar
Mobil 1 synthetic on taper roller bearings.
1948F-1Pickup is offline   Reply With Quote
Old 05-30-2020, 08:34 PM   #15
JM 35 Sedan
JM 35 Sedan's Avatar
That's also what I use on the rear hub roller bearings. I buy it at NAPA. They don't usually carry it on their store shelves, but they will order it in from their central warehouse, and have it for pick up in their local store the next day.
John
Old 05-30-2020, 09:53 PM   #16
Will D
Will D's Avatar
Project Farm is great! Unbiased, evidence based testing to the best of his abilities.
I always hear grease is grease.... They are not all the same.
Old 05-30-2020, 11:48 PM   #17
FL&WVMIKE
FL&WVMIKE's Avatar
Yea, he's awesome! Here is a test of where he compared a vintage grease from the 1940's to a modern grease.
https://www.youtube.com/watch?v=l7hp..._Qpe2dkKi2vRG6
Here is his Youtube page where he has TONS of videos comparing about everything you can think of. Always look for his data before buying anything. lol
https://www.youtube.com/channel/UC2r...6N1X-wuOg_p0Ng
Old 06-01-2020, 05:26 PM   #18
Don
Don's Avatar
Napa had the Sta Lube 3131 ,ordering morning get in afternoon,glad I got ,look like the grease I used 50 yr,ago ,,I’m sure this is better for the old cars,thick and fiber!!
DON P
Old 06-01-2020, 08:08 PM   #19
FL&WVMIKE
FL&WVMIKE's Avatar
If you watch those Project Farm Youtube Videos that were posted, you'll see:
Lucas 'Red and Tacky'
Walmart Grease
High grade Marine Grease
Grease from the 1940's.
They found all grease is NOT created equal. Grease has come a LONG way since back in the day, and cheap grease doesn't work nearly as well as the higher quality offerings out there. Across the two videos, you'll see how the Lucas makes the others look like Silly Putty. lol Looking at the wear marks on the bearings in the friction/protection test, you'll see the Walmart and 1940's grease did TERRIBLE, and the Lucas had barely any damage.
Nostalgia is great for some things, but lubricants have come a LONG way since back then!
Good Luck!
Old 06-05-2020, 02:07 AM   #20
Will D
Will D's Avatar
Walmart Grease
Good Luck!
Don't forget that what Project Farm conducts is "lab" based studies/procedures which don't always aline with real world situations. Data is great but many factors can sway a result or paint a picture that is skewed. As we learned first hand from school, theory is not always practical.
I don't believe his results necessarily apply to sta lube 3131 as it is a completely different type of grease than tested and compared by project farm. The grease he tests is general/multi purpose lithium based, while sta3131 is a drum brake specific sodium based short fiber grease. It's comparing apples to oranges.
Sta3131 is a modern grease not a 40 yr old unopened can of grease. It resembles fibre filled grease from back in the day as it compares in looks and texture as the Lucas and Wal-Mart grease compared in looks and texture to the 40yr old unopened grease.
Something designed for a specific purpose is better suited for that purpose than a general or multi purpose item, wouldn't you think?
Thread Tools
Display Modes
