04-04-2016, 05:12 PM | #1 |
31 front brake rods
so this being my first time bulding and A , I need to know how the front brake rods go on as in is the round eye end supposed to go through the anti rattle part ? mine will not but there is a slot on the anti rattler that looks like it should work that way. the rattler pushes the brake rod towards the wheel correct?
also the book shows 51 1/2" but the rods set to that length are 1/2' to short to work |
04-04-2016, 05:25 PM | #2 |
Re: 31 front brake rods
All 4 threaded ends of the brake rods face forward. If you use repro brake rods, then you may have to grind the eye some to make it fit through the spring slot for the front rods.
04-04-2016, 05:29 PM | #3 |
that's what I thought thanks just making sure
04-04-2016, 08:37 PM | #4 |
If you are referring to the measurement Les Andrews list in his red book. It is not correct. This error has been pointed out many times here. For safety make sure you have a minimum thread engagment length equivalent to the diameter of the rod in the clevis.
04-04-2016, 11:12 PM | #5 |
ok so what should the brake rod lengths be, for starters? im new at all this
04-05-2016, 12:11 AM | #6 | |
The complete brake procedure is in the SERVICE BULLETINS. |
