02-20-2015, 05:05 PM | #1 |
'38 one ton cab mounting blocks
I'm looking for any information regarding cab mounting blocks for a '38 one ton. The frame is not the same as a 1/2 ton, and the blocks would be unique. I had no wood in the truck when I got it to work from.
02-20-2015, 08:14 PM | #2 |
Re: '38 one ton cab mounting blocks
Post your question over on the FTE (Ford Truck Enthusiasts 1947 and older): http://www.ford-trucks.com/forums/forum42/
There have been posts about big truck mounting blocks.
Making the simple complicated for over 30 years. |
02-20-2015, 10:45 PM | #3 |
I made my own from some old oak pallets and a band saw. Fortunately, I had the old ones for templates. The front in the two first pictures are the tapered ones, the furthest bolt to the front I used some old cut valve springs for movement. Sorry I don't have pictures for the front as it is masked for paint. The rear is approximately a 2x4 spanning from one side to the other. The center is basically shims, 1 and 1/4" by 4" on each side. I used some thin (1/8") bias ply rubber between wood and metal all around.
02-21-2015, 10:01 AM | #4 |
Bob |
