Old 02-18-2015, 07:39 PM   #1
Larry
Default Identify Rear Axle
I have a 1937 Ford, the letters and numbers on the axle are: CD134 E the 3 and 4 are a quarter turn and the is E sets off at an angle. Any help in identyifing the gear ratio would be helpful. Thank you.
Larry is offline   Reply With Quote
Old 02-18-2015, 09:44 PM   #2
JSeery
JSeery's Avatar
Default Re: Identify Rear Axle
Those are not the correct numbers for the gear ratio. Sometimes the numbers are very faint or only partially there. Might post a photo. 9/34 would be 3:73 & 9/37 would be 4:11.
