Old 09-22-2014, 07:14 PM   #1
Mike B
Default Where can I find Oil Bath filter screen mesh?
Not specifically for these cars, is for a tractor I'm working on...and need quite a bit more than an Early V8 would have.
The local supplies want me to buy a new complete filter, I just want to pry things apart, and put in new mesh.
Thanks
Mike B is offline   Reply With Quote
Old 09-22-2014, 07:36 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: Where can I find Oil Bath filter screen mesh?
Grocery stores sell it to scrub pots and pans with.
Old 09-22-2014, 08:12 PM   #3
Mike B
That's the same?
Ya ain't yanking my chain are you Lawson?
Old 09-22-2014, 08:25 PM   #4
cmbrucew
cmbrucew's Avatar
MikeB
I bought a bunch at the swap meet for a quarter each.
Done two air cleaners.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 09-22-2014, 08:27 PM   #5
Mike B
Is it copper mesh, or?...
Old 09-22-2014, 11:24 PM   #6
Gary Tosel
Gary Tosel's Avatar
I believe the mesh is similar to Chore Boy which is for scrubbing pots and pans. Look carefully at the package to be sure it is copper and not copper colored plastic or other material. For a pure restoration it is not the same, but for function with oil film added for an air filter will work.
Gary Tosel is offline   Reply With Quote
Old 09-23-2014, 06:12 AM   #7
BABAR40
BABAR40's Avatar
I think Joblot in Long Island has the pick up screens. They have an amazing amount of parts.
BABAR40 is offline   Reply With Quote
Old 09-23-2014, 06:51 AM   #8
gundoca
gundoca's Avatar
I have seen it at Tractor Supply for tractors, but it was not copper.
gundoca is offline   Reply With Quote
Old 09-23-2014, 09:07 AM   #9
Lawson Cox
Lawson Cox's Avatar
Originally Posted by Mike B View Post
That's the same?
Nope. Same stuff, or at least it used to be.
Old 09-23-2014, 09:12 AM   #10
TomO
Any good hardware stoe sells copper wool in several grades.
TomO
TomO is offline   Reply With Quote
Old 09-23-2014, 10:35 AM   #11
Mike B
Thanks all
Old 09-23-2014, 11:12 AM   #12
hook00pad
Try Dennis Carpenter. They sell Ford tractor parts.
hook00pad is offline   Reply With Quote
Old 09-23-2014, 02:19 PM   #13
37coop
37coop's Avatar
To save me opening a separate post.
On my 51 f1 I have put on the carb an oil air cleaner that I,v had had hanging around for years ,I didn't realise it but this post indicates it has the oil AND wire mesh .I thought it was just the oil,am I right or wrong ,thanks Jim.
37coop is offline   Reply With Quote
Old 09-23-2014, 06:06 PM   #14
Mike B
I've never seen an oil bath aircleaner with out a mesh screen
Old 09-23-2014, 11:14 PM   #15
gnolnor
gnolnor's Avatar
Buy a Chore Boy copper pot scrubber. Take it apart by unwinding the
copper scrubber. It will be longer than wide when unwound. Feed one
end into the place where the old mesh was. It took two pieces to fill
the space. Only cost $1! I did this on my '36 and it worked just fine.
gnolnor is offline   Reply With Quote
Old 09-24-2014, 02:29 PM   #16
37coop
37coop's Avatar
o.k guys ,I will have to find some copper pan scourers as advised or I assume stainless steel will be as good , does the mesh go in the oil trough with the oil ,I,m sure it sounds a dumb question but I have never used an oil bath filter before ,thanks Jim.
Old 09-25-2014, 08:59 AM   #17
rdmace1956
rdmace1956's Avatar
I used the nylon stuff in a tractor air cleaner but since I have found that they sell copper mesh for pest control. Next time I will probably use that.
rdmace1956 is offline   Reply With Quote
Old 09-25-2014, 09:35 AM   #18
mfagan
mfagan's Avatar
Fordbolts.com
AIR CLEANER GOODIES
M-92-01 1934-1936 Air Cleaner Element and Screen assy. Proper copper mesh filter material and fresh cadmium
plated square hole 5 point wire screen as original.
M-92-02 1937-1941 Air Cleaner Element and Screen assy.
R-87-07 Special fillister Head Screw for 32-34 air cleaners R-306 Dry Type Air Cleaner – clamp hardware. The correct
fillister head screw and square nut in Ford S-2 Finish
(2pcs/pkg)
R-86-06 Exact duplicate of the stamped steel wing nut used on
1934-1948 air cleaners. We’re proud to offer this difficult to find, troublesome item that has been a source of frustration to most of us.
$ 19.95/kit $ 24.95/kit
$ 1.50/ea $ 2.50/pkg
$ 2.50/ea
__________________________________________________ ___________________________ M-92-04 Correct Wire Screen filter element replacement for 1935 $ 5.50/ea
thru 1937 Duck Bill Oil Breather. __________________________________________________ ___________________________
Call Roy
mfagan is offline   Reply With Quote
