02-29-2020, 04:51 PM | #1 |
Valve clearance for 38 21 stud
I’ve read a lot on how to do valve but have not found anywhere we’re a person has given the correct settings ,these are non adjustable valves!have all the tools so going old school all I need is the lash settings. ,thanks
I think I have used .012 I and .014 on ex
DON P |
02-29-2020, 05:42 PM | #2 |
Re: Valve clearance for 38 21 stud
My old Motors manual say's .012I&.014EX.
02-29-2020, 05:53 PM | #3 |
Thanks that’s what I’m going with !!!!!
DON P |
02-29-2020, 08:32 PM | #4 |
It really depends on the cam and the cam grinders specifications. If it is stock, then it is Fords specifications.
03-01-2020, 09:05 AM | #5 |
In .012 Ex .014 too tight just take time grinding the stem. I made a fixture just a piece
of pipe that fits the valve stem and clamped that to the side fine grinder wheel. As I grind and rotate the valve to the wheel just nipping it check & repeat. Lash too loose, then you have to reface the valve and or the seat, to set it deeper. |
03-02-2020, 07:24 PM | #6 |
"Came too close to dying to stop living now!" |
