Old 01-22-2019, 01:51 PM   #1
36roadster
Default 1936 convertible vs 1935 fordoor
Hi IM wondering IF i Can Put a Ford 1935 fordor floor and rear wheeltubs
At my 1936 convertible with rumle seat? Is it anyone thath tried that operation?
36roadster is offline   Reply With Quote
Old 01-22-2019, 02:12 PM   #2
DavidG
DavidG's Avatar
Default Re: 1936 convertible vs 1935 fordoor
The forward 80% of the floor is same for all '35-'36 passenger cars with some minor differences in terms of wood underfloor reinforcements and the number of fasteners retaining the battery cover. The rear 20% of the floor in cabriolets, roadsters,and coupes is unique to those body types.
Old 01-22-2019, 11:39 PM   #3
VeryTangled
VeryTangled's Avatar
Greetings Everyone! 36roadster, you have received a wonderful answer from a contributor that has done your type of job before and seen many many cars that you ask about.
-Jeff H
Old 01-23-2019, 11:35 AM   #4
Mike in AZ
Mike in AZ's Avatar
Welcome to the ‘Barn. Have any pics you want to share? Mike
Mike in AZ is offline   Reply With Quote
Old 01-23-2019, 02:30 PM   #5
36roadster
Thanx for info, best reugards Göran
Old 01-23-2019, 05:44 PM   #6
Viv W
David is correct.
When I was restoring my 35 phaeton, I bought a 35 4 door sedan and took the floor out of the sedan to replace the phaeton one, but I still had to cut out and repair some rusty areas. I also had remains of very rotten 36 roadster body and wanted to use bits of the rear floor for patches, but no such luck. Basically the roadster floor from the back seat riser to the rear is completely different in design and will NOT interchange.
I seem to recall the inner wheel wells were different too.
Viv.
Viv W is offline   Reply With Quote
Old 01-23-2019, 08:18 PM   #7
uncle buck
uncle buck's Avatar
Originally Posted by Viv W View Post
David is correct.
Viv.
I believe you are correct on the wheel wells too.
uncle buck is offline   Reply With Quote
Old 01-24-2019, 12:29 AM   #8
rich b
rich b's Avatar
Not the best pictures to compare; but they may give you an idea on how different the back sections differ, coupe rear section on the left, sedan floor on the right.
