03-22-2015, 12:22 PM | #1 |
Transmission Leak
I have a big leak on my 1937 Ford transmission. I was wondering if anyone could tell me what is involved with dropping the transmission to put new seal/gaskets in it? Thank you
03-22-2015, 12:54 PM | #2 |
Re: Transmission Leak
What's leaking? Where?
03-22-2015, 04:57 PM | #3 |
It looks like it is leaking on the top/back end of transmission. The fluid is traveling from the back down to the drain plug.
03-22-2015, 05:00 PM | #4 |
Question: Do you happen to have a lot of 'rake' on the car? (big and littles, dropped axle, etc).
Is it possible the torque tube is running at a downward angle toward the transmission . . . or is the car pretty much stock height and the torque tube angles down toward the banjo rear as Henry built it? |
03-22-2015, 08:37 PM | #5 |
Have a 2" drop, but it leaked before I dropped it.
03-23-2015, 03:57 AM | #6 |
"Came too close to dying to stop living now!" |
03-23-2015, 11:46 PM | #7 |
Some leak from the rear around the layshaft and reverse idler shaft where they push into the housing. Geoff
