09-27-2019, 07:51 PM | #1 |
How to delete PM's
Guys,
My PM mail box is 99% full....how do I delete some ? Charlie ny |
09-27-2019, 08:00 PM | #2 |
Re: How to delete PM's
Charlie I'll try and get these pictures in order. But on the right is a box, check it, then go to the bottom and click on the move to folder option, under it is other options. Pick delete. Then hit go. Done.
I try to clean mine up every few months. Keep the ones you want and delete the rest. Frees up server space also. Hope this helps! |
09-27-2019, 08:10 PM | #3 |
Also if you want to goto your oldest pm's there is a 123...etc at the top. Click on the biggest number and there you are at the oldest pms.
09-27-2019, 08:26 PM | #4 |
If the above didn't help
Go to PM's At the top you have a box which you can choose "INBOX" or "SENT ITEMS". Inbox always come up first. Select which you want to delete. Below box will be the INBOX items . For those you want to delete, click on the small box to the right of the item. In same section at the bottom right there is a box with different selections - select DELETE. Then click on GO. Messages selected will be deleted. Same for "SENT" items, except DELETE at bottom is first selection.
09-27-2019, 08:28 PM | #5 |
Good call Paul. Have to go through both. Lot of repeats.
09-28-2019, 06:04 AM | #6 |
Charlie |
