10-03-2023, 08:50 PM | #21 | |
Re: 40 Ford Ignition Woes
Good call Ken.
10-04-2023, 08:00 AM | #22 |
You can eliminate the cap/rotor by checking the output of the coil. No spark there (along with no spark at a plug) says it is not a cap/rotor problem.
You have 6.2 volts at the coil. What do you have at the points side. Steady 0 would imply that the points stay closed, while 6.2 volts would imply that the points remain open. Assuming you have an analog meter, a slow crank speed should show some needle movement that the points are opening and closing. |
10-04-2023, 10:41 AM | #23 |
I put a jumper between the neg battery post and the neg side of coil. Still no spark. It's frustrating because the system is so simple. I am looking to the cap and rotor next.
10-04-2023, 10:47 AM | #24 | |
10-04-2023, 11:55 AM | #25 |
Cap, rotor or wires.
These have caused me trouble before. I mentioned it in post #2. I replied having only read page 1. If you have pos ground and touch a neg jumper to the neg side of the coil it probably won't generate a spark. You need to have a constant neg feed to the coil and intermittently connect between the pos terminal on the coil and ground. It should generate a spark as you remove the contact with the ground. |
10-09-2023, 12:06 PM | #26 |
10-09-2023, 12:22 PM | #27 |
Thirdgen auto is the go to place. Michael is very helpful.
Flathead enthusiast - 1933 Phaeton |
10-09-2023, 12:47 PM | #28 |
be careful. The "crab" cap with the wires exiting sideways is (something like) 41-42. A 47 cap would be the rabbits ears type cap. The rotor arm is specific to each type.
10-09-2023, 05:10 PM | #29 |
Does this mean either type is ok for the 47 crab as long as you run the right rotor for a given cap?
10-09-2023, 05:16 PM | #30 |
Well, what I was really getting at is what type of cap do you currently have? If a crab type, you need the crab type again. If a rabbit ears type, you might want one of those, but might want to go to a crab type for simplicity.
The term "47 crab" in not strictly correct. In 47 the distributor was the same as the earlier ones (true crab type) but was modified to take a new cap, which is nicknamed the rabbit ears type cap. From an ease of fitment point of view, the earlier crab cap is the popular choice. Mart. |
10-09-2023, 06:25 PM | #31 |
The 47-48 has a two piece cap… a real pita to work on. The 42-46 has the crab type cap that many prefer. The only difference is the cap, rotor, and retaining clips. We offer all three items all made in the USA
10-10-2023, 09:17 PM | #32 |
I'm no know it all but what I'm seeing and hearing here is a loose or corroded connection heating up and losing continuity. I would start at the battery and work my way to the points cleaning and checking resistance at each and every connection. I had a little experience with this when I bought my 41 pickup. It took me awhile but I found it. Tim
