Old 10-03-2021, 10:23 PM   #1
Afordman31
Afordman31's Avatar
Default Antique Engine Rebuilding
Rumor that they are going out of business the end of the year! Anyone else heard that?
Afordman31 is offline   Reply With Quote
Old 10-04-2021, 04:52 AM   #2
chrs1961815
chrs1961815's Avatar
Default Re: Antique Engine Rebuilding
Not a rumor, Rich is retiring.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 10-04-2021, 07:13 AM   #3
Mike Peters
Mike Peters's Avatar
Yep X 2. Rich is retiring. Heard it from a man who works for Rich.
Mike Peters is offline   Reply With Quote
Old 10-04-2021, 10:49 AM   #4
Russ/40
Russ/40's Avatar
Does that jeopardise the availability of his insert rod beatings?
Old 10-04-2021, 01:23 PM   #5
chrs1961815
I have been wondering that too - will he continue to make them? Should have asked him a few weeks ago.
Old 10-04-2021, 02:32 PM   #6
1931 flamingo
1931 flamingo's Avatar
IF you're going to need them, NOW is the time to buy. JMO
Paul in CT
Old 10-04-2021, 03:03 PM   #7
alexiskai
alexiskai's Avatar
Paul in CT
That's good advice about Stipe shocks and Burtz blocks and pretty much any unique part these days.
Old 10-04-2021, 05:40 PM   #8
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Rich's parts business is a separate thing, He is actively trying to sell that now..
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 10-04-2021, 06:15 PM   #9
Synchro909
Synchro909's Avatar
Let me get this straight. So the rods and bearings sold by the likes of Snyders are made by Rich and is he the maker of the main bearing inserts for the likes of the Burlington or Scat crank shafts?
If yes to the above, I assume I can buy direct from him. Yes/no?
Old 10-04-2021, 06:46 PM   #10
Oldbluoval
Oldbluoval's Avatar
You’d think Snyder’s or Bert’s would pick it up if not overpriced.
I’ve had numerous situations but the numbers just absolutely sucked.
The ROI was just no where close
Old 10-04-2021, 07:05 PM   #11
Mike Peters
Arnold: I have heard where Rich gets his inserts, rods, etc., but you really should call Rich directly at 847-674-6716 eastern Central Time to get the whole story.
Old 10-04-2021, 07:06 PM   #12
Mike Peters
Correction: Should read just Central time, not eastern central time. Sorry.
Old 10-04-2021, 08:56 PM   #13
Synchro909
Synchro909's Avatar
Thanks Mike. I'll get up early (I hate that!) and ring him soon.
Old 10-05-2021, 02:58 AM   #14
updraught
updraught's Avatar
https://www.antiqueenginerebuilding.com/highwaycar.html
Previously if you wanted a Burlington crank in a rebuilt engine for us here in OZ it was probably worth just getting a rebuilt short block with hi comp head, Stipe cam and lightened flywheel all shipped by sea.
Down left on the website are the parts.
Probably best to go with a new engine now tho ...
updraught is offline   Reply With Quote
Old 10-05-2021, 05:26 AM   #15
SAJ
SAJ's Avatar
SYNCHRO, I have Snyders rods and inserts in my roadster. They are not from AER. The inserts have side thrust walls, imitating the original Ford rod Babbitt. AER inserts do not.
I don't know if this is a good thing or not, since most common modern shells do not incorporate side thrusts.
SAJ in NZ
SAJ is offline   Reply With Quote
Old 10-05-2021, 04:09 PM   #16
Synchro909
Synchro909's Avatar
SAJ in NZ
In all of the inserted A engines I have, there is no side thrust face on the insert. That is taken care of by 3 bronze crescents placed in machined recesses in the block so maybe mine are from AER.
Old 10-05-2021, 08:08 PM   #17
Jim Mason
Jim Mason's Avatar
He's selling to somebody in Indiana. The guy is working with for a month or so to learn how he builds engines.
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
Old 10-06-2021, 02:39 AM   #18
SAJ
SAJ's Avatar
Synchro I was referring to the conrod insert shells 9 which have 2 side thrust faces moulded in to each one. Not crankshaft end thrust babbit replaced by bronze thrust washers.
SAJ in NZ
Old 10-06-2021, 11:56 AM   #19
abachman3
abachman3's Avatar
Rich was at Gilmore/Hickory Corners two weeks ago at the Model A Ford Museum. He had the new buyer with him and he was introducing him to folks there. The buyer runs a machine shop in Blufton, Indiana, just south of Ft. Wayne. I'm not sure of the timing on all of this. The small parts is a separate business and is for sale.
abachman3 is offline   Reply With Quote
Old 10-06-2021, 02:27 PM   #20
Big hammer
Hoping the new owner keeps AER name and web site, sounds like the new owner working with Rich it will flawless turnover
get a bigger hammer tap done
