05-27-2014, 12:00 PM | #21 | |
Re: Y-block 292 Timing question
Smtichy, like Y-Blockhead mentioned, ported vacuum is correct and not straight manifold vacuum. There should be no vacuum to the distributor advance when at a warm idle speed. When you crack the throttle open slightly you should get vacuum there because you expose the ported vacuum hole in the throttle bore to manifold vacuum (below the throttle plate). Here is a link to the article on how to convert you're 4000 carb for '57 and later distributors. Sal Cicala http://www.eatonbalancing.com/blog/2...-distributors/ |
05-27-2014, 02:02 PM | #22 |
Sal, Many thanks for that link. Now I get how it works!
I think my advance problems started from my cleaning up the incorrectly hooked up vacuum tube which was plugged up ... Geez. I'll probably run it with the vacuum advance disconnected for now, and see how it goes. If that does the trick, I'll make this an Autumn project as I don't think my wife will be pleased with my putting the car out of commission just after I've told her it's purring like a kitten and all ready for the season. Guys, as always thanks for the pointers.
Steve '55 Sunliner - 292 V8, 3 speed man. w/ OD ČKMAA - Český klub majitelů amerických automobilů |
05-27-2014, 05:46 PM | #23 |
Steve,
You should be OK running without the vacuum advance for now. As long as you have centrifugal advance, the engine will get what it needs to run good when the RPM gets up higher. Only thing it will hurt is not enough spark advance at light loads which will hurt the fuel economy a little bit and slightly higher exhaust temps. Good luck, Sal |
05-28-2014, 07:53 AM | #24 |
Here's something to think on. I believe it to be true and correct. I run manifold vac on my street built 357 Ranchero engine....RooDog
Re: Ported vs manifold vacuum advance March 21st, 2012, 09:36 AM This was the post I found on a MOPAR forum during a google search. This was written by a former GM engineer as a response to a similar question on a Corvette board: As many of you are aware, timing and vacuum advance is one of my favorite subjects, as I was involved in the development of some of those systems in my GM days and I understand it. Many people don't, as there has been very little written about it anywhere that makes sense, and as a result, a lot of folks are under the misunderstanding that vacuum advance somehow compromises performance. Nothing could be further from the truth. I finally sat down the other day and wrote up a primer on the subject, with the objective of helping more folks to understand vacuum advance and how it works together with initial timing and centrifugal advance to optimize all-around operation and performance. I have this as a Word document if anyone wants it sent to them - I've cut-and-pasted it here; it's long, but hopefully it's also informative. TIMING AND VACUUM ADVANCE 101 The most important concept to understand is that lean mixtures, such as at idle and steady highway cruise, take longer to burn than rich mixtures; idle in particular, as idle mixture is affected by exhaust gas dilution. This requires that lean mixtures have "the fire lit" earlier in the compression cycle (spark timing advanced), allowing more burn time so that peak cylinder pressure is reached just after TDC for peak efficiency and reduced exhaust gas temperature (wasted combustion energy). Rich mixtures, on the other hand, burn faster than lean mixtures, so they need to have "the fire lit" later in the compression cycle (spark timing retarded slightly) so maximum cylinder pressure is still achieved at the same point after TDC as with the lean mixture, for maximum efficiency. The centrifugal advance system in a distributor advances spark timing purely as a function of engine rpm (irrespective of engine load or operating conditions), with the amount of advance and the rate at which it comes in determined by the weights and springs on top of the autocam mechanism. The amount of advance added by the distributor, combined with initial static timing, is "total timing" (i.e., the 34-36 degrees at high rpm that most SBC's like). Vacuum advance has absolutely nothing to do with total timing or performance, as when the throttle is opened, manifold vacuum drops essentially to zero, and the vacuum advance drops out entirely; it has no part in the "total timing" equation. At idle, the engine needs additional spark advance in order to fire that lean, diluted mixture earlier in order to develop maximum cylinder pressure at the proper point, so the vacuum advance can (connected to manifold vacuum, not "ported" vacuum - more on that aberration later) is activated by the high manifold vacuum, and adds about 15 degrees of spark advance, on top of the initial static timing setting (i.e., if your static timing is at 10 degrees, at idle it's actually around 25 degrees with the vacuum advance connected). The same thing occurs at steady-state highway cruise; the mixture is lean, takes longer to burn, the load on the engine is low, the manifold vacuum is high, so the vacuum advance is again deployed, and if you had a timing light set up so you could see the balancer as you were going down the highway, you'd see about 50 degrees advance (10 degrees initial, 20-25 degrees from the centrifugal advance, and 15 degrees from the vacuum advance) at steady-state cruise (it only takes about 40 horsepower to cruise at 50mph). When you accelerate, the mixture is instantly enriched (by the accelerator pump, power valve, etc.), burns faster, doesn't need the additional spark advance, and when the throttle plates open, manifold vacuum drops, and the vacuum advance can returns to zero, retarding the spark timing back to what is provided by the initial static timing plus the centrifugal advance provided by the distributor at that engine rpm; the vacuum advance doesn't come back into play until you back off the gas and manifold vacuum increases again as you return to steady-state cruise, when the mixture again becomes lean. The key difference is that centrifugal advance (in the distributor autocam via weights and springs) is purely rpm-sensitive; nothing changes it except changes in rpm. Vacuum advance, on the other hand, responds to engine load and rapidly-changing operating conditions, providing the correct degree of spark advance at any point in time based on engine load, to deal with both lean and rich mixture conditions. By today's terms, this was a relatively crude mechanical system, but it did a good job of optimizing engine efficiency, throttle response, fuel economy, and idle cooling, with absolutely ZERO effect on wide-open throttle performance, as vacuum advance is inoperative under wide-open throttle conditions. In modern cars with computerized engine controllers, all those sensors and the controller change both mixture and spark timing 50 to 100 times per second, and we don't even HAVE a distributor any more - it's all electronic. Now, to the widely-misunderstood manifold-vs.-ported vacuum aberration. After 30-40 years of controlling vacuum advance with full manifold vacuum, along came emissions requirements, years before catalytic converter technology had been developed, and all manner of crude band-aid systems were developed to try and reduce hydrocarbons and oxides of nitrogen in the exhaust stream. One of these band-aids was "ported spark", which moved the vacuum pickup orifice in the carburetor venturi from below the throttle plate (where it was exposed to full manifold vacuum at idle) to above the throttle plate, where it saw no manifold vacuum at all at idle. This meant the vacuum advance was inoperative at idle (retarding spark timing from its optimum value), and these applications also had VERY low initial static timing (usually 4 degrees or less, and some actually were set at 2 degrees AFTER TDC). This was done in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it. If you look at the centrifugal advance calibrations for these "ported spark, late-timed" engines, you'll see that instead of having 20 degrees of advance, they had up to 34 degrees of advance in the distributor, in order to get back to the 34-36 degrees "total timing" at high rpm wide-open throttle to get some of the performance back. The vacuum advance still worked at steady-state highway cruise (lean mixture = low emissions), but it was inoperative at idle, which caused all manner of problems - "ported vacuum" was strictly an early, pre-converter crude emissions strategy, and nothing more. What about the Harry high-school non-vacuum advance polished billet "whizbang" distributors you see in the Summit and Jeg's catalogs? They're JUNK on a street-driven car, but some people keep buying them because they're "race car" parts, so they must be "good for my car" - they're NOT. "Race cars" run at wide-open throttle, rich mixture, full load, and high rpm all the time, so they don't need a system (vacuum advance) to deal with the full range of driving conditions encountered in street operation. Anyone driving a street-driven car without manifold-connected vacuum advance is sacrificing idle cooling, throttle response, engine efficiency, and fuel economy, probably because they don't understand what vacuum advance is, how it works, and what it's for - there are lots of long-time experienced "mechanics" who don't understand the principles and operation of vacuum advance either, so they're not alone. Vacuum advance calibrations are different between stock engines and modified engines, especially if you have a lot of cam and have relatively low manifold vacuum at idle. Most stock vacuum advance cans aren’t fully-deployed until they see about 15” Hg. Manifold vacuum, so those cans don’t work very well on a modified engine; with less than 15” Hg. at a rough idle, the stock can will “dither” in and out in response to the rapidly-changing manifold vacuum, constantly varying the amount of vacuum advance, which creates an unstable idle. Modified engines with more cam that generate less than 15” Hg. of vacuum at idle need a vacuum advance can that’s fully-deployed at least 1”, preferably 2” of vacuum less than idle vacuum level so idle advance is solid and stable; the Echlin #VC-1810 advance can (about $10 at NAPA) provides the same amount of advance as the stock can (15 degrees), but is fully-deployed at only 8” of vacuum, so there is no variation in idle timing even with a stout cam. For peak engine performance, driveability, idle cooling and efficiency in a street-driven car, you need vacuum advance, connected to full manifold vacuum. Absolutely. Positively. Don't ask Summit or Jeg's about it – they don’t understand it, they're on commission, and they want to sell "race car" parts. PS: The combustion chamber don't care what name is on the valve covers.... |
05-28-2014, 11:28 AM | #25 | |
So why then did all American auto makers design engines to run using ported vacuum ? Also done by competent engineers. In my eyes it doesn't really matter since you get full manifold vacuum advance as soon as the throttle is touched the slightest amount. I'm also aware of how it all works from many years of working in engineering doing dynamometer work and calibration. |
05-28-2014, 10:52 PM | #26 |
In the article above he speaks of retarded timing to heat the exhaust to make the air injector more efficient for emmission reasons. Read it again, most things are explained. I do know that more advance leads to a smoother idle & higher vacuum meter readings, but the tuner must contend with starter kickback. Ever deal with an old lick start Harley Panhead? If so the effects of retarded vs advanced timing during starting can be painfully obvious. There is another writeup, on the web somewhere where, the author drove with dual vacuum gages, ported and manifold, and once under way they read the same, only at idle was there a diff. Choose you own poison and draw your vacuum advance from where it feels best to you and your engine.....I'll take mine straight, but bourbon and branch is OK too....RooDog |
08-01-2019, 09:05 PM | #27 |
Hi Scicala: I saw that you had recently worked on a 54 Merc 256 ci with the Teapot Carb. I've got a problem with mine that I don't understand. I have to unplug the vacuum advance to keep the engine from back firing continuously. After much adjustment - checking valve lash, timing chain (new), distributor (rebuilt by Concours) Carburetor rebuild by professional, I'm not getting anywhere. Vacuum at the carb is about 4 in. Manifold vacuum is 17 plus in. Timing is advanced beyond the pointer. Any ideas anyone?? Thanks Timmy D, C'ville, OK
08-01-2019, 09:47 PM | #28 | |
What carb and distributor does it have? An original '54 'teapot' and Load-o-matic or something else? At first glance they may look much like the '55 versions. Are there part or casting #'s on them? Is there an EBY prefix casting number on the block at the base of the distributor, on the heads and across the rear of the intake manifold? What is the vacuum line for the distributor connected to, a carb port or the intake manifold? A Load-o-matic timing advance operates on 0 to 5 inches of vacuum, intake manifold vacuum will be way too high. If the timing marks are on an old original crank pulley damper ring a common problem is for the ring to slip, then the timing marks don't line up any more. Can you post a photo of the crank pulley & timing pointer? Not sure it would run even as well as it currently is, but... was the new timing chain installed properly? .(photo 1) IF, either of these things has happened you may need to re-confirm #1 TDC (compression stroke) and/or valve & crankshaft timing. . Last edited by dmsfrr; 08-06-2019 at 11:57 AM. |
