02-19-2016, 02:16 PM | #41 |
Re: I have a question about horse power
That is true.. As a boy when I heard a car was 200HP, I imagined a Roman Chariot driven by Carlton Heston being pulled by 200 horses!
02-19-2016, 02:49 PM | #42 | |
As for Ford's flat head V8 the crank shaft was pushed from two angles as oppose to one in an inline engine and were pushing at the right sequence to increase power... Think of two 80 lbs kids at play ground spinning one of these below... say standing 60 degrees apart, and timed just right.. as opposed to a single 160 lbs kid from just one point... which could push more kids on the ride? The two working together can produce more torque.
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio Last edited by mshmodela; 02-19-2016 at 03:04 PM. |
02-19-2016, 10:34 PM | #43 |
It's all about efficiency.
If you take as factual, the HP advertised as 40 hp, just for comparison, The model A engine is 20% efficient., or 1/5 hp for every cubic inch. The model B then is 25%, 1/4 hp for every cubic inch. The 32 V8 then becomes 29% The last 255 cubic inch Mercs become (depending on what advertising), about 40% efficient. Highly modified V8's (flatheads) can be up to 75% efficient and more. Most of the increased efficiency in the V8s come about from the individual intake ports, more power pulses and increased usable rpm. The lack of individual intake ports (shared ports) on the model A/B really reduces the engine's efficiency. A model A/B would be better off using the exhaust for the intakes, which I guess some have tried. That, or the 2 up/2 down crank, which would help some. Just an observation |
02-20-2016, 12:16 AM | #44 |
I don't see how horsepower per cubic inch can be directly connected with efficiency. I just think of efficiency as how far a given amount of gasoline can move a given weight of car. If an engine was 100% efficient, then it wouldn't need coolant nor a radiator because all the heat of the burning fuel would be converted to mechanical energy moving the car.
02-20-2016, 11:34 AM | #45 | |
02-20-2016, 01:34 PM | #46 |
02-22-2016, 05:14 PM | #47 |
Some newer 4 cylinder engines are capable of more than 100 HP per Liter
02-22-2016, 11:10 PM | #48 |
If the Model A was that efficient, it would develop about 330 bhp.
02-22-2016, 11:13 PM | #49 | |
The main difference comes down to its easier to fill a small cylinder than a big one.
