Old 04-23-2018, 11:07 AM   #1
Tacoma Bob
Tacoma Bob's Avatar
Question Drag link "innards"
I'm finding two different orientations for the spring, cups etc. In the Model "A" Ford as Henry built it ( Edition three) page 43 a technical illustration shows the pitman arm end of the drag link. What I'm seeing is a spring (next to the zerk) ball cup, pitman arm ball and then the end plug. Snyder's A-3305-S Instructions at the zerk end shows a spherical cap, pitman arm ball, ball cap, spring and then the end plug. Thoughts.
Tacoma Bob is offline   Reply With Quote
Old 04-23-2018, 01:17 PM   #2
SeaSlugs
SeaSlugs's Avatar
Default Re: Drag link "innards"
If i remember right one end is one way the other is the other way. Look at your drag link - one end is definitely closer to the threaded side than the other. Both ends should have a zerk otherwise how would you lube the ball?
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 04-23-2018, 02:05 PM   #3
Bob C
The picture on page 43 is the old design. The design changed in Oct 1928. Basically
the drag link was turned end for end. See page 290 of the Service Bulletins.
Bob
Old 04-23-2018, 02:11 PM   #4
Tacoma Bob
Tacoma Bob's Avatar
Bob
Thanks Bob, I did check the SB. So the Snyders version would be correct?
