Old 03-20-2018, 10:19 PM   #1
Tacoma Bob
Tacoma Bob's Avatar
Default Spindle bolt bearings Timkin T 83
Redoing king pins and the "kit" I purchased has some shady looking bearings. I have searched here and my findings indicate the Timkin T-83 are out of production. Also I did not find any felts in the kit. Will any felt work or is there something special about the felts in the kit? Current thoughts?
Tacoma Bob is offline   Reply With Quote
Old 03-20-2018, 11:56 PM   #2
Randy in ca
Randy in ca's Avatar
Default Re: Spindle bolt bearings Timkin T 83
Mac's has USA made thrust bearings for $6 apiece. Where did you purchase the kit?
Randy in ca is offline   Reply With Quote
Old 03-21-2018, 09:54 AM   #3
Tacoma Bob
Tacoma Bob's Avatar
Bought the kit from a regional supplier. I'm sure they will send up the two large felts. In reading Les Andrews and the forums the good timkins are no longer available. I would rather hunt for quality bearings than run the risk of beaing failure. I check Mac's out too. Made in Ohio or so they claim. LOL
Old 03-22-2018, 12:28 AM   #4
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Try McGuire bearing
Old 03-22-2018, 01:13 AM   #5
J Franklin
J Franklin's Avatar
The king pin bearings get very little actual use that causes wear.
Old 03-22-2018, 07:23 AM   #6
jw hash
jw hash's Avatar
Bob I have the bearings you need. are you going to the meeting tonight, if so I will bring a pair. John
jw hash is offline   Reply With Quote
Old 03-22-2018, 10:06 AM   #7
Tacoma Bob
Tacoma Bob's Avatar
Hello John... Yes please although inspecting mine they seem very usable. The re-pops I bought are so-so. What really chaps my ass is I borrowed one of the clubs king pin reamers and somebody chipped the hell out of several teeth. I don't feel comfortable using it. I also found 2-3 wheel lugs are a bit loose. Can these be re-swaged? I'm going to Thoes this morning to install new bushings. See you tonight. And Thank You.
Old 03-22-2018, 10:06 AM   #8
Tacoma Bob
Tacoma Bob's Avatar
Originally Posted by Chuck Sea/Tac View Post
Try McGuire bearing
went to McGuire yesterday..........no-go.
Old 03-22-2018, 10:08 AM   #9
Tacoma Bob
Tacoma Bob's Avatar
[QUOTE=J Franklin;1608011]The king pin bearings get very little actual use that causes wear.[/QUOTE
That's my feeling too and I also found no shims.
Cheers TB
