09-15-2012, 05:57 PM | #1 |
Grease in the steering gear
I decided to check the oil in my 29 Gemmer steering gear yesterday. I was surprised to find a black grease,instead of 600 weight oil. Is this a common thing,or a poor fix for another problem?
If you think SBC's are "Old School" you are not old enough. |
09-15-2012, 06:03 PM | #2 |
Re: Grease in the steering gear
Poor fix.
09-15-2012, 06:16 PM | #3 |
And also a common thing too.. Does yours have a fill plug or a grease fitting ?? Many have grease fittings and back in the day shops would fill a grease gun with heavy oil..
09-15-2012, 10:44 PM | #4 |
Mine has a plug. I seem to remember reading on this forum about using John Deere oil or grease for a corn picker.
09-15-2012, 10:46 PM | #5 |
Use 600W. You may have to take your box apart and clean it so the 600W works correctly.
09-16-2012, 06:46 AM | #6 |
The corn head grease has been used by some fellas in the u-joint housing.. |
09-16-2012, 09:28 AM | #7 |
STP also works well. No high speed gear issues and thick enough it doesn't leak.
09-16-2012, 09:34 AM | #8 |
The "black stuiff" could be something like bentonite oil --if you dip a screwdriver in it will it slowiy fill the divot back in, and sort of run off the end of the screwdriver a little ---even if it is grease adding the proper oil will lube the gear by filling in the space movement makes in grease
09-16-2012, 09:49 AM | #9 |
Penn Rite steering box lube, Restoration Specialties, Escondido, CA, doesn't leak out, about 12-12 $ + shipping, on line catalog
Paul in CT |
09-16-2012, 11:35 AM | #10 |
It is definetly grease,looks like chassis grease,or wheel bearing grease. I may try adding some 600.
09-16-2012, 12:36 PM | #11 |
1955-? Chevy boxes initially called for oil , later factory service bulletins changed that over to grease, because of leaks........end of leak problems and it didn't affect the box.
Gene USN |
09-16-2012, 12:38 PM | #12 |
I took some bad advice and filled my steering box with grease. After reading posts on the Fordbarn, I removed as much grease as possible through the fill plug opening. I then refilled with the Penrite steering box lube. I have not noticed any leaks and it steers much easier.
09-16-2012, 02:15 PM | #13 |
Gene, that chevy box is a bit different than the Ford one. I have added light oil to a '36 Chevrolet box that was filled with grease and it seemed to mix and thin the grease.
09-16-2012, 02:35 PM | #14 | |
I'd just leave the grease and add the heavy gear oil and not worry about it. |
09-16-2012, 06:53 PM | #15 |
1931 Flamingo,
I tried looking on Google for Restoration Specialties, Escondido, CA and couldn't find them. Can you direct me to their online catalog? Thanks, Robert |
09-16-2012, 07:48 PM | #16 |
Ok, here goes. If you have access to the May-June 1998 “Model ‘A’ News” (Vol 45 No. 3), there is an article entitled “Best Steering Gear Grease” by Herman Reheis of Monticello GA, discussing his use of Ford Steering Gear Grease, Ford Part No. C3AZ-19578A. Mr. Reheis asked George DeAngelis if he was aware of this product (which he wasn’t). Mr. DeAngelis looked into the matter and responded to Herman with a letter and 3 pages of data from the Ford archives, the bottom line (as Mr. Reheis states in his “Model ‘A’ News” article) being that Ford responded to the effect that the product was a “grease used as a long life lubricant for steering gear housings and is expected to last for the life of the vehicle.” Mr. Reheis goes on to state that he had (as of 1998) used this grease for over 30 years in the restoration of more than 50 steering gears. A couple of years ago the local Ford parts department crossed this part number for me to a Motorcraft product, Ford Part No. CGX-1C, which has Ford Specification ESA-M1C75B.
[Dare I say the following? Oh, why not...] This is the product I've used in my 2-tooth steering gear for several years now, with no problems. I will - as they say - await the firestorm off-line...
Skip Keyser Napa Valley A's Olympic Vintage Auto Club (1980-1982) MARC of San Diego (1977-1978) MAFCA (since 1978) MARC (since 1977) ---------- Model A owners belong in their Model A’s; Model A’s belong on the road. |
09-16-2012, 10:29 PM | #17 |
Napa Skip, thanks for that information. I know George Deangelis,and live close to him. I drove my "T" hot rod by his house today,I usually see him at the local swapmeets. I will never know what grease is in the box right now. I guess since it ain't broke I will leave it alone,or just add a little 600.
09-17-2012, 10:51 AM | #18 | |
09-17-2012, 11:33 AM | #19 | |
Restoration Supply Company 15182-B Highland Valley Road Escondito, CA 92025 800-306-7008 www.restorationstuff.com [email protected] Penrite steering box lube, part number LUB009 Tom Endy |
09-17-2012, 01:23 PM | #20 |
Tom: My bad, thanks for updating. A little CRS
Paul in CT |
09-17-2012, 07:26 PM | #21 |
Lubricating the bushings in the sector shaft housing will not be as good with heavier grease because it won't flow in to that area like an oil. Compounds like 600w will flow into the gaps even though it is a "thick oil" or "lube".
