Old 11-30-2020, 11:51 AM   #21
Mart
Mart's Avatar
Default Re: flathead engine stand
Like JSeery above I, too, took advantage of the natural 45 degrees formed when using a piece of angle iron.
Next time you happen across a couple of foot length of heavy angle iron you should be saying to yourself "Ooh! Flatty side mount!".
Old 11-30-2020, 02:34 PM   #22
V8COOPMAN
V8COOPMAN's Avatar
Ya know, Mart.....This is only ONE of the many reasons you've become a famous YouTube movie star of note, well on your way to making million$......'CUZ YOU'VE GOT a 'special' sense of humor! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 12-01-2020, 06:31 PM   #23
WBrown
WBrown's Avatar
He also has a "special" sense of know how
Aim low--achieve your goals.
WBrown is offline   Reply With Quote
Old 12-03-2020, 01:47 AM   #24
mercman from oz
mercman from oz's Avatar
This is what you need, a proper Engine Stand, built especially for the Flathead Ford V8 Engines. You get two of those side clamps, bolt one to each side of the Block then add the Engine to the Stand. Can't go wrong with this style Engine Stand. It is super strong and you can rotate the Engine into 4 positions and then Lock in place at the desired position. See Clamp on left, bottom photo.
Old 12-03-2020, 06:48 AM   #25
Mart
Mart's Avatar
^^ The one above is a nice sturdy unit. The only downside is that the deck surface is never horizontal which is better if trying to bore it.
Mart.
Old 12-03-2020, 09:36 AM   #26
big job
big job's Avatar
My way without buying cheap stands and driving your brain and taking up shop room.
A good bench with casters. Factory engines were built up vertically not on a engine
stand. All operations were done that way. The plus is, we have a roll away bench which
is always busy doing other work. I then built a top of oh 20 gauge with a lip and a
drain hole in the middle bucket underneath for cleaning etc. Only cost was the casters
hardware store the rest lumber we had from other jobs.. Not new idea I saw the engine
line on Yo-tube back when....
big job is offline   Reply With Quote
Old 05-08-2021, 03:51 PM   #27
Howard Wade
Many thanks for the suggestions. If i buy a flat head side mount is one enough or do you mount one both sides of the engine. Thanks
Howard Wade is offline   Reply With Quote
Old 05-08-2021, 04:07 PM   #28
Ford Freak
One has always worked fine for me . - F F
1952 Ford F1
1965 Ford Falcon Sprint
2007 Ford Mustang GT
Ford Freak is offline   Reply With Quote
Old 05-08-2021, 04:08 PM   #29
V8COOPMAN
V8COOPMAN's Avatar
Howard.....All you need is ONE. In fact, two would be difficult to use! Welcome to F'Barn! DD
T5 W/TORQUE TUBE
Old 05-08-2021, 07:35 PM   #30
Zax40
Zax40's Avatar
I just ordered one from Stumpy’s last week. It showed up in less than a week. Got my spare flathead mounted to the stand with it today. Pretty happy with it. For those of you using this style mount how hard is it to flip the motor over on the stand? One man or two man job?
Zax40 is offline   Reply With Quote
Old 05-08-2021, 08:41 PM   #31
tubman
tubman's Avatar
I will quote Roy D. Mercer here : "How big a' boy are ya'?"
Old 05-08-2021, 11:53 PM   #32
JSeery
JSeery's Avatar
I can do it and I'm old and weak!
Old 05-09-2021, 03:13 AM   #33
Mart
Mart's Avatar
One man job. Does it have a hole for a bar to go through? I use a 30" bar on mine and can turn it over. It's a bit heavy when fully built but still do-able.
Mart.
Old 05-09-2021, 06:25 AM   #34
51 MERC-CT
51 MERC-CT's Avatar
Mart.
Had a spare boat winch, Soo, guess what.
