Old 12-29-2017, 12:49 PM   #1
Terry, NJ
Terry, NJ's Avatar
Default identifying an H.C. head, How?
On one of my coupes, I have a indistinguishable looking head. It runs pretty good so I'm suspicious that someone put a HC head on it. But I don't know. Do the after market manufacturers use some sort of marking system so their heads can be identified at a later date? The engine runs fine so I don't want to rip it down at this time.
Terry
Old 12-29-2017, 01:20 PM   #2
steve s
steve s's Avatar
Default Re: identifying an H.C. head, How?
Check the compression.
steve s is offline   Reply With Quote
Old 12-29-2017, 02:58 PM   #3
Charlie Stephens
Take some photos especially any markings on the head and post them. Maybe someone will recognize something. You could also find out by running a compression test.
Charlie Stephens
Old 12-29-2017, 08:13 PM   #4
James Rogers
James Rogers's Avatar
Stock heads from Ford have a tiny bump just above the water pump below the water outlet. Snyder heads have 2 bumps on the driver side with 5 small pin pricks in each. Brumfield heads are marked with a B-F. Ford police heads have a large B or C cast in them. Other than that all bets are off and you will have to remove the head and check the combustion chamber. I have seen heads with several different names cast in them such as the lion head and a Hoof head I have. There are many aluminum heads with varying compression ratios such as the Thomas and cyclone heads among many others.
James Rogers is offline   Reply With Quote
Old 12-30-2017, 11:17 AM   #5
Anteek29
Anteek29's Avatar
So, what is the expected compression for a stock head?
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 12-30-2017, 11:55 AM   #6
Terry, NJ
Terry, NJ's Avatar
14.7 (one atmosphere) X 4.2 = About 60lbs, But you have to add some for the heat generated during compression, so about 65 lbs with good rings and valves. However, What's the compression of a, say a 5.5 CR head , By my calculations, it will be around 75- 80 Lbs. Your compression may vary! Temperature, humidity altitude, and probably cranking speed, all of these will vary from day to day.
Terry
Old 12-30-2017, 05:59 PM   #7
29er
29er's Avatar
Terry
I installed a new Snyder 5.5:1 head last August in my '29er. A compression test then resulted in 75# plus/minus 1# for each cylinder.
Mike in Orygun
29er is offline   Reply With Quote
