12-29-2015, 09:33 AM | #1 |
ford fordor 1940 v8 won't start whwn warm
My ford fordor 1940 V8 won't start whwn the engine is warm
when it is cold it starts, it gets fuel and the engine turns round can someone help me |
12-29-2015, 09:39 AM | #2 |
Re: ford fordor 1940 v8 won't start whwn warm
Check your coil, could be a bad condenser as well. Sure sounds like you've got an ignition issue.
12-29-2015, 09:53 AM | #3 |
Oke thanks, i try to find out if the are stil oke
12-29-2015, 10:27 AM | #4 |
does the engine stall when warm, and then refuse to start? then look at the coil and condenser. When you stop the car after it is warm it then refuses to restart? Will it start again if you wait only a few seconds or only after a couple of minutes then no restart? if so look at the carburetor power valve leaking aroung gasket or defective diaphragm and leaking through there. Does it not start because it is turning over very very slowly or hardly at all? Then look for a bad battery cable or incorrect cable size or dirty cable connections. More detail would be helpful.
12-29-2015, 11:10 AM | #5 |
The engine does not stall wen it is warm. it runs very smoothly when it is warm and it also eactrs to the gas pedal very well but when it is turned of and it stands for 10 or 15 minutes it wil not start, the starter engine turns good round and when i push the start button it try to fire up for 1 oder 2 seconds and then it doent goes on when i try to start it up when it is stopped and directly afther started it will start again.
12-29-2015, 11:17 AM | #6 |
12-29-2015, 11:42 AM | #7 |
oke thanks i try it my carb is also flooding
what kind of a carburator do you have Last edited by jan quaak; 12-29-2015 at 12:05 PM. |
12-29-2015, 08:16 PM | #8 |
battery cables loose, it will crank good but not getting the right voltage to the coil. i had that trouble would not start when it was hot. the cables where loose on the starter switch. tightened them up and then it cranked right up
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
12-29-2015, 08:39 PM | #9 |
12-29-2015, 09:18 PM | #10 |
Try by passing the resister with a jumper wire & see if it will crank. If it does put a diode wire from the starter side of relay to coil that will solve your problem.
'40Garage |
12-29-2015, 09:41 PM | #11 |
Get your coil rebuilt
12-29-2015, 10:37 PM | #12 |
I had the same problem with a '57 Chevy I once owned. It would start easily when cold with outside temperatures in the minus 20 below zero range. When the engine reach normal operating temperature and then was turned off, it would not start again until it cooled way down. Replacing the resistor resolved this problem....
12-30-2015, 08:03 AM | #13 |
This is typical of 99.9% of all Ford coils from 1932 to 1948.
Even new NOS coils and most repro coils have this problem. Skip Haney in Florida rebuilds the stock coils using modern insulation of the wire and material between layers which solves the problem plus almost a lifetime warrantee. In 20 years of rebuilding service Skip has never charged for repair of any coil he rebuilt other then a few that left the ignition switch on and the points were closed. This dead shorts the wiring and burns the them up. Original coils also give a weak spark as they get hot. Almost every old coil will work good when cold. A coil must be tested cold and hot to determine how it works. Contact [email protected] for info. G.M.
www.fordcollector.com |
12-30-2015, 02:15 PM | #14 | |
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
