Old 05-01-2014, 07:54 PM   #1
Hotrodvideo
Hotrodvideo's Avatar
Default '37 one ton truck
I'm not a truck guy so I have to ask.
Do the 1/2 ton and one ton trucks have the same cab and front sheet metal?
Hotrodvideo is offline   Reply With Quote
Old 05-01-2014, 08:02 PM   #2
flat-v8
flat-v8's Avatar
Default Re: '37 one ton truck
Same cab as 1\2 ton but bigger fenders, grill, and hood are the same.
flat-v8 is offline   Reply With Quote
Old 05-01-2014, 11:00 PM   #3
41panelmark
41panelmark's Avatar
Nice Av8 roadster, did you work on the Guitars Grease film?
41panelmark is offline   Reply With Quote
Old 05-04-2014, 09:46 AM   #4
oldandtired
The hood, grill, inner grill panel interchange. The cabs are essentially the same except the pickup has a seat riser with a pan underneath it and the truck has an underseat tank. The steering columns do not interchange. The 1 1/2 ton frequently had marker lights on the top of the cab that the pickup did not have. The fenders, inner fender panels, and running boardsdo not interchange. The headlight buckets were not all the same in 37 trucks and pickups...some had the headlight stand recessed toward the rear more than in 35/6 and there were two different height headlight stands.
oldandtired is offline   Reply With Quote
