Old 12-11-2013, 07:48 PM   #1
Idaho Brett
Idaho Brett's Avatar
Default Wiring Diagram Clarification
Does the wire going from the Generator Cut-Out Relay to the Junction Box connect to the BATT or ARM side of the relay?
Or is it one of those things that makes no difference because the relay is not sensitive to polarity? Thanks.
Idaho Brett is offline   Reply With Quote
Old 12-11-2013, 07:58 PM   #2
Mitch//pa
Default Re: Wiring Diagram Clarification
Connects to the battery side
If you were to connect it to the gen side you would have a draw with the car off
