03-16-2020, 04:22 PM | #1 |
Rear end out of a dune buggy
I disassembled a very old dune buggy about 35 years ago. Did not want my son and his buddies to kill themselves. It was a shortened flathead chassis of an unknown year. Here is the rear end. What year might it be.
I also have the front axle, wishbone and spring. We will be moving and I do not want to take it with me. |
03-16-2020, 04:30 PM | #2 |
Re: Rear end out of a dune buggy
measure across where the brake backing plates mount, thats the normal method to id it
03-16-2020, 05:44 PM | #3 |
03-16-2020, 04:36 PM | #4 |
Looks like 37-40 at first glance.
Is there just a single eye on the spring perches? |
03-16-2020, 05:55 PM | #5 |
Top of front axle
03-16-2020, 06:31 PM | #6 |
Also has the earlier style shape of the the torque tube |
03-16-2020, 07:56 PM | #7 |
So that must be a 37-38 front axle?
03-16-2020, 10:48 PM | #8 |
qmdv, Your 53" at the backing plate doesn't match your tape measure 481/2" at the spring hangers. Something funny there, so check this Street Rodder article and measure your rear end again.
http://goldengatev8.org/images/Stree..._magazine.html
Alan |
03-16-2020, 10:52 PM | #9 | |
03-16-2020, 10:54 PM | #10 | |
Not according to the pictures you posted. check your pictures and read the article.
Alan |
03-16-2020, 11:18 PM | #11 | |
I was looking for that article. It was a pdf for a bit. Think I have it but... Thank you Some more stuff. Last edited by Tinker; 03-16-2020 at 11:35 PM. |
03-16-2020, 11:47 PM | #12 |
03-16-2020, 11:07 PM | #13 |
Just read the article and it was very informative. And my bad. The 48 1/2 was at the spring perch holes of the rear end. I later measured the distance at the point of were the backing plates bolt up and that is 53 inches. The article tells me that it is a 42 to 48. The front and rear brakes were the later type hydraulic. And the front axle top spring perch holes were 40 3/4.
The engine was not a 59AB (but that could have been changed) Had a side shift trans. So now that I know it is all 42 to 48 I can put it all up for sale. Too heavy to ship so it will probably be pick up only |
03-16-2020, 11:09 PM | #14 |
ford38v8-thats a great article, thanks for looking it up
03-16-2020, 11:16 PM | #15 |
Front axle looks like a '42 up axle with that perch bolt spacing.
03-16-2020, 11:50 PM | #16 |
Maybe... what do i know, best of luck duder seriously, Look up spring dimensions. but...
03-17-2020, 12:05 AM | #17 |
48-two holes-first year of tube shocks if i remember correctly, which is asking for a lot
03-17-2020, 12:09 AM | #18 |
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 03-17-2020 at 03:35 PM. |
03-17-2020, 12:13 AM | #19 |
... Thank you pete
another fav Last edited by Tinker; 03-17-2020 at 01:12 AM. |
03-17-2020, 10:48 AM | #20 |
