05-02-2020, 03:18 PM | #1 |
Starter issue
My starter is doing something I have never seen or heard before. It engages just fine but after startup there is a bad noise like the bendix is not disingaging. After a few seconds it goes away but it happens every time I start it. I took the starter out and there is nothing wrong with the bendix. There is witness marks from the ring gear on the pinion like it it has been scraping on it. Engine is a ‘36 and the starter I grabbed from an 8ba. It was a manual trans 8ba that it came from. Any thoughts?
Respecting and Resurrecting Ford Model A's. |
05-02-2020, 04:09 PM | #2 | |
Re: Starter issue
Phil NZ |
05-02-2020, 04:27 PM | #3 |
Re: Starter issue
do you have the oil pan to starter support in place? bent shaft on starter can cause this, rough teeth on flywheel or Bendix, too much grease and junk on Bendix "threads"
05-03-2020, 09:38 AM | #4 |
Re: Starter issue
There shouid be NO lube on the Bendix. JMO
Paul in CT |
05-03-2020, 10:02 AM | #5 |
Re: Starter issue
05-03-2020, 12:02 PM | #6 |
Re: Starter issue
05-03-2020, 01:34 PM | #7 |
Re: Starter issue
Pull the starter, remove the armature and ck to see if it's bent. I had a A with a bent armature on the Bendix end. I also recently had a new V8 starter where the armature was out of round, causing problems as it occassionaly rubbed the field coils.
Paul in CT |
05-04-2020, 04:32 PM | #8 |
Re: Starter issue
Nothing visually wrong with mine. Nothing bent. Went over to my buddy Kevin’s shop and got the starter off a ‘40 engine he has and it works just fine on mine. No noises. So something must be up with mine.
