01-26-2018, 08:56 AM | #1 |
1955 F100 vin paint color
Curious to what some members here might know what color my f100 should be by looking at the vin. The frame is stamped f10D5CL6984. I know it's a Chester build. Any help much appriciated. As I prep the truck, I'm finding yellow paint.
01-26-2018, 11:57 AM | #2 |
Re: 1955 F100 vin paint color
I don't think the vin will tell you the color. You need to go off the data tag. It should be on the glove box lid.
1956 Ford Fairlane Town Sedan 292 V8 with Ford-o-Matic |
01-26-2018, 02:36 PM | #3 | |
Here a link to an example data plate for '55 & '56 full sized cars. Some of the '55 exterior color codes may be the same. (pdf document, opens in a new window) https://thecvaonline.com/howtos/DataPlateDecoder.pdf EDIT - better links.... Here's a decoder for '55 Ford trucks... http://www.1955fordtrucks.com/1955-ford-trucks.html and a few other misc links.. https://www.google.com/search?q=1955...nt=firefox-b-1 . Last edited by dmsfrr; 01-26-2018 at 03:11 PM. Reason: add links |
01-26-2018, 03:02 PM | #4 |
The '55 truck and car color code for Goldenrod Yellow is L (M20j-358) which may be the L in your frame code, however, there should be a data tag on your glove box door as Herman mentioned.
02-06-2018, 12:31 AM | #5 |
The Colonial White mix for my '57 F100 was not even close, only to find it was a 1959 formula, but no one told me until after I'd sprayed some. |
