12-25-2016, 07:25 PM | #1 |
Hub cap ID
12-25-2016, 07:41 PM | #2 |
Re: Hub cap ID
The lower picture is '32-'34 4 cylinder.
Charlie Stephens |
12-25-2016, 07:49 PM | #3 |
Re: Hub cap ID
Top picture is 1934....Should be painted Ford Blue to be correct....
12-25-2016, 08:06 PM | #4 |
Re: Hub cap ID
I believe the lower 4 cyl cap is for 32 and 33. 34 4 cyl doesn't have the concentric ridges, it is just the single ring out by the edge like the v8 cap.
12-25-2016, 08:16 PM | #5 |
Re: Hub cap ID
Here are the six varieties of early Ford Hubcaps to suit the Wire Wheels fitted to 1932 - 1935 Fords.. 1932 Ford V8 - Top Left 1932-1933 Ford "4" - Top Centre 1933 Ford V8 - Top Right 1934 Ford "4" - Bottom Left 1934 Ford V8 - Bottom Centre 1935 Ford V8 - Bottom Right |
12-25-2016, 08:25 PM | #6 |
Re: Hub cap ID
12-25-2016, 09:46 PM | #7 |
Re: Hub cap ID
I don't understand....I can view the pictures in the original post to this thread but I can't view mercman's pictures. Anyone else experiencing this?
12-26-2016, 12:44 AM | #8 |
Re: Hub cap ID
Petehoovie-
I have no trouble. You might try closing FB and re opening it. |
12-26-2016, 06:21 AM | #9 |
Re: Hub cap ID
Pete, are you logged in?
12-26-2016, 11:46 AM | #10 |
Re: Hub cap ID
I agree with Big Red 51. Sounds like your not logged in. Ford Barn boots you out after a period of inactivity.
Sal |
12-26-2016, 02:23 PM | #11 |
Re: Hub cap ID
Yeah, I'm logged in. See, my little green lamp below my Avatar is ON....
12-26-2016, 03:20 PM | #12 |
Re: Hub cap ID
Clean out your "history" to see if that helps.
12-26-2016, 06:11 PM | #13 |
Re: Hub cap ID
It's the browser I'm using - Firefox. I was able to view mercman's photo when I logged in using Internet Explorer. I'll have to do some tweaking with Firefox....
12-31-2016, 01:30 AM | #14 |
Re: Hub cap ID
Are the locking caps of same appearance?
I have a very nice locking, it looks most like the 34 4 cylinder one. Did locking caps have V8 on them too,? I have never seen one without an oval door flap with ford logo. |
12-31-2016, 03:07 AM | #15 |
Re: Hub cap ID
32 & 33 V8 locking caps have the V8 on the swing away lid.The 34 and 35 share the same oval swing away lid.The 34 cap skin reveal around the oval is wider.The 35 skin oval is the same all the way.34 & 35's appear on EBAY all the time and most of of the time not identified correctly.
12-31-2016, 03:34 AM | #16 |
Re: Hub cap ID
Pooch...here's a 1932 Model B hubcap with circular lock cover
12-31-2016, 03:49 AM | #17 |
Re: Hub cap ID
Here is a Lineup of the 1932 to 1935 Ford Hubcaps as fitted to Wire Wheels, including Locking hubcaps. The only one that I am missing in my display is the 1932-1933 Locking Hubcap, as pictures above. |
12-31-2016, 05:20 AM | #18 |
Re: Hub cap ID
Here is a comparison picture of the 1934 and 1935 Ford Locking Hubcaps. The top one is 1934, and is wider at each end under the movable Ford Oval, as "Deuce lover" pointed out. As there was a Ford script and no V8 Symbol on the 1934 Locking Hubcaps, it was used on both the 4 and V8 models. For 1932 and 1933, two different Locking Hubcaps were issued, one for the 4, the other for the V8. The lower picture shows the 1935 Ford Locking Hubcap. |
12-31-2016, 12:03 PM | #19 |
Re: Hub cap ID
Also, the 32 V8 locking cap lock cover has a block style V8 and the 33 has the more elegant looking curved V. This is just on the cover that swings away to reveal the lock.
12-31-2016, 09:39 PM | #20 |
Re: Hub cap ID
Just to confirm and illustrate what Deuce Roadster mentioned, the "V8" in the 1932 Ford V8 Hubcap is "old style", while the "V8" in the 1933 Ford Hubcap is much more "streamlined". Top photo is 1932 and lower photo is 1933. |
