Old 04-26-2021, 09:31 AM   #1
[email protected]
modela@aol.com's Avatar
Default How often does a Model A have a need for a tow truck?
My local Model A club just had a picnic meeting this past Saurday to start off our new touring season.
One of the members was talking about having a front axle that was all twisted and bent. Discussion turned to how the tow trucks would often put a hook or chain on the axle and yank on them causing these axle issues.
The discussion then turned to who had to get towed back home after their Model A died on the road and why.
Here is the listing of what the failures were to kill off their cars on the road:
1.) Broken rear axle
2.) Sheared rear axle key
3.) Failure of an original universal joint
4.) Failure of a modern repro ignition cable. ( Plastic insert at spring end softened up then not making contact with disti.
5.) Crack in head causing severe overheating
6.) Broken fuel line caused by vibration
7.) Bottom half of Zenith carburetor falling off while driving
8.) Original cast clutch arm breaking
9.) Loss of fuel when the silver foil coin sized seal off of a bottle of Heet fell into the gas tank being sucked over the fuel outlet.
10.) Modern "leak proof" water pump failing when the adjusting nut lip seal pushed out.
There is a flip side also as there were no stories of bad condensers, coils, or point issues. Also no flat tires or running out of gas. Overall not too bad for a group of guys that have driven their Model A's thousands of miles over the last 30 years....
What issues have you folks experienced to make you hitch a ride on a flat bed truck. Let me know what to add to this listing....
modela@aol.com is offline   Reply With Quote
Old 04-26-2021, 09:40 AM   #2
700rpm
700rpm's Avatar
Default Re: How often does a Model A have a need for a tow truck?
I needed a tow home two years ago after never needing on in 58 years of deiving my A. The cause was bad gas. My own fault for leaving gas in the tank over the winter without Stabil.
It was a flatbed tow but I still made sure the tow guy didn’t attach anything to my front axle.
Ray Horton, Portland, OR
Old 04-26-2021, 09:41 AM   #3
Bob Bidonde
Bob Bidonde's Avatar
I have been driving my 45B Coupe since 1962 (50,000 + miles) and not once did it need a tow truck. On the other hand, my 190A Victoria needed a ride home on a flat bed once in 1993 because the threads on the left rear axle stripped and the wheel came off.
Lesson learned from the 190A is do not torque the axle nut more than 50 lbs-ft.
Bob Bidonde
Bob Bidonde is online now   Reply With Quote
Old 04-26-2021, 12:11 PM   #4
Mike Peters
Mike Peters's Avatar
1. broken clutch arm
2. broken rear axle
Both these events required a flat bed ride.
Mike Peters is offline   Reply With Quote
Old 04-26-2021, 01:17 PM   #5
pjdeb
pjdeb's Avatar
So, if you need a tow or pull onto a flatbed, where is the best place to hook up?
pjdeb is offline   Reply With Quote
Old 04-26-2021, 01:22 PM   #6
Patrick L.
Patrick L.'s Avatar
Axle nut or lug nut ?
Old 04-26-2021, 01:32 PM   #7
Ruth
Yes, please clarify. I torque my axle nuts to 100 lbs-ft. Have I been going too high?
Ruth
Old 04-26-2021, 01:49 PM   #8
Kurt in NJ
Kurt in NJ's Avatar
Stock A has little need, but if you have modern "improvements ", then you need towing like modern cars
Old 04-26-2021, 04:25 PM   #9
GPierce
GPierce's Avatar
A member on tour with us had to ride a rollback home when his electronic ignition failed and no one had a module or a spare distributer.
GPierce is offline   Reply With Quote
Old 04-26-2021, 04:52 PM   #10
Bruce of MN
Bruce of MN's Avatar
I keep four axle straps in the trunk. If the strap is looped around the front axle at the wishbone connections, it should be ok IMO.
Old 04-26-2021, 05:03 PM   #11
fried okra
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
An interesting and informative thread.
fried okra is offline   Reply With Quote
Old 04-26-2021, 05:14 PM   #12
JBill
But not one likely to produce peace of mind for the summer driving season ahead!
JBill is offline   Reply With Quote
Old 04-26-2021, 07:46 PM   #13
Synchro909
Synchro909's Avatar
In 50,000 miles, I have had to put the A on a truck twice. First time was after it stood for hours in pouring rain and the top of the motor got wet through the middle hinge. If I had time, it would have eventually dried but the forecast was for 3 more days of rain. The second time was poor diagnostics by me. The distributor body was breaking down and causing the notorious #3/#4 cross fire. We were on our way home from a run of 12,000 miles and I'd lost patience with it after a few thousand miles of it misbehaving.
FWIW, once I got it home, I looked deeper into it and found the problem. I had a spare body with me and a rotor button so I replaced them both. I only got a few miles and it stopped again. After a tow home behind my wife's modern car, I found that the lug inside the rotor button was missing. It was not broken off, it was never there. That allowed the button to spin on the shaft causing the timing to be all over the place. It sounded like WW3 when it stopped and I was in traffic so I couldn't do much on it where it died, otherwise, I would have found that problem and fixed it in a flash.
Sometimes, no amount of preparation/maintenance can prevent a "failure to proceed".
Old 04-27-2021, 06:11 AM   #14
Chris in WNC
Chris in WNC's Avatar
sheared rivets in the clutch disc, at national meet in Marquette.
our next Model A is out there in the unknown......
Chris in WNC is offline   Reply With Quote
Old 04-27-2021, 07:17 AM   #15
old31
I also have been torquing my axles nuts to 100-110 lbs. Lug nuts 55.
old31 is offline   Reply With Quote
Old 04-27-2021, 07:20 AM   #16
old31
Strange, what would cause that?
Old 04-27-2021, 08:39 AM   #17
Bob Bidonde
If you must transport your broken Model A, the safest and best way is on a flatbed truck.
In the case of my Victoria, the car was new to me and I foolishly drove it before thoroughly inspecting it. The nut securing the drum to the left rear axle stripped-off. It was held on by a cotter pin!
Bob Bidonde
Old 04-28-2021, 06:10 AM   #18
SAJ
SAJ's Avatar
After high speed runs through the hilly turns to Napier city, I pulled up to the first roundabout and, as I tried to turn, the steering wheel came up towards me and the car went straight on. I pushed the wheel down hard and made it round the roundabout but there was a terrible shimmy as i went down the road. At a max speed about 5 mph I made it to our hotel, where I parked the car for the duration and had it flat-decked 300 miles back to my workshop.
Somehow the bottom thrust bearing in my 7 tooth box had let all the rollers escape, and the steering wheel was climbing up and down the sector instead of rotating it.
I fitted a Gemmer box from a later car and steering feels much nicer, but there were no real symptoms of impending failure in the old box - just 3 inches of slack at the rim, which most of the Model A's I had observed seemed to have.
Lesson learnt, and a lucky escape. And rather exciting for the lady traffic warden that was desparately trying to prevent me from going straight through her roundabout barriers and into the cordoned-off parking area for the coming veteran parade cars!
SAJ in NZ
SAJ is offline   Reply With Quote
