04-15-2021, 04:14 PM | #1 |
Head gasket question
I was told when I bought it that my 1930 A has an
After market high compression head but I don't Know the brand. I want to buy a spare head gasket don't Know what to buy. Any suggestions? |
04-15-2021, 04:33 PM | #2 |
Re: Head gasket question
Hmmmm. I have had a high compression head on this my 3rd engine. I have never bought a spare gasket for one.
Does the head have any markings, or embossing on it? |
04-15-2021, 04:35 PM | #3 |
I use the model B graphite head gasket from snyders with my 5.5 head from them also.Some prefer the copper gasket.
04-15-2021, 04:36 PM | #4 |
04-15-2021, 04:37 PM | #5 |
Take the old gasket to a vendor so you can do a comparison. I bet a BEST graphite gasket (my choice) will do the job.
04-15-2021, 04:38 PM | #6 |
04-16-2021, 04:15 AM | #7 |
04-20-2021, 09:36 AM | #8 |
When I ordered my 5.5 head from Snyder I also ordered a copper head gasket.
A Snyder rep called and said not to use a copper head gasket and he changed my order to a B-6051-XO head gasket, and said do not use any type of sealant. |
04-20-2021, 09:20 PM | #9 |
04-20-2021, 09:50 PM | #10 |
Bad Bob, Model A heads require periodic re-tightening. Since you don't know when the last re-tightening was done, that should be top on your agenda. Follow the recommended sequence and torque to 55 foot-pounds in 10 foot-pound stages. Do this with the engine cold and repeat every 6 months. If you keep the head tight you probably won't need a head gasket.
I use the Best graphite gasket for the B engine with my Snyder 5.5 head. I used the copper spray gasket sealer.
04-21-2021, 03:06 AM | #11 |
Nice thread guys.
04-21-2021, 12:31 PM | #12 |
Most vintage performance heads required a Model A gasket, as opposed to the B gasket. The important thing is for the gasket to fit the head, don't worry about fitting the block, it is totally flat.
