Old 06-16-2010, 01:46 PM   #1
Bill H.
Default Engine noise
While cruising along around 30 - 35, I hear a "ticking" noise from the engine. When I retard the spark lever just a couple of degrees, the noise goes away. What's wrong?
Bill H. is offline   Reply With Quote
Old 06-16-2010, 02:14 PM   #2
Special Coupe Frank
Special Coupe Frank's Avatar
Default Re: Engine noise
When you hear the ticking-noise, if you let-off the accelerator slightly, does the noise lessen / disappear ?
If so, it sounds like "pinging" from a little too much advance ?
( Just speaking from my post-Model A upbringing ... my Ford has so many knocks and rattles that I keep expecting to see hay-bales popping-out the rumble-seat ! )
Special Coupe Frank is offline   Reply With Quote
Old 06-16-2010, 02:32 PM   #3
Rainmaker Ron
Rainmaker Ron's Avatar
Sometimes a particular noise will never be found. I have noted that loose wrist pins will quiet down by retarding the spark. Experiment at engine speeds just above an idle.
Rainmaker Ron
Rainmaker Ron is offline   Reply With Quote
Old 06-16-2010, 03:35 PM   #4
Bruce
Bruce's Avatar
I agree with Ron. Also, if you have a police or other high(er) compression head, your car will likely require less spark advance. This is especially true up hills or into a head wind. Notch it back a couple.
Bruce is offline   Reply With Quote
Old 06-16-2010, 04:53 PM   #5
Karl
Karl's Avatar
I get a ticking noise in my coupe but seems independent of advance or retard I didn't notice it until I installed the original vacuum wiper. I'm sure the noise is just normal valve train noise that is now being transfered up the vacuum line to resonant on the firewall . Now I don't even notice it . It is my experience with hard to locate rattles and noises in cars they either go away on there own or get so bad its easy to identify them and fix them . Karl
Karl is offline   Reply With Quote
