Old 03-03-2014, 03:45 PM   #1
Mike
Mike's Avatar
Default turn signals for a 35 ford coupe
To all,
I have to install turn signals on a stock 35 Ford coupe, what is my best choice to go with ? The customer does not want a signal stat in the column.
Thank you,
Mike
Mike is offline   Reply With Quote
Old 03-03-2014, 03:59 PM   #2
Charlie Stephens
Default Re: turn signals for a 35 ford coupe
Originally Posted by Mike View Post
To all,
Thank you,
Mike
I think some of the Model A suppliers (Bratton's?) sell a kit with a toggle switch that can be mounted anywhere.
Charlie Stephens
Old 03-03-2014, 04:33 PM   #3
41PICUP
41PICUP's Avatar
painless Wiring has a setup that uses a toggle switch.
Part number 30120, I think.
Used it on my 41 pickup.
41PICUP is offline   Reply With Quote
Old 03-03-2014, 04:43 PM   #4
Mike
Mike's Avatar
thanks guys I will check it out
mike
Old 03-03-2014, 04:46 PM   #5
mrtexas
mrtexas's Avatar
This is better than the one Model A suppliers sell IMHO. Self cancelling by time.
http://www.turnswitch.com/Turnsignal.htm
mrtexas is offline   Reply With Quote
Old 03-03-2014, 05:14 PM   #6
flatheadfan
flatheadfan's Avatar
Mike-
I have a '35 and a '36 and in both cases I have a dual gauge under the dash for oil pressure and temperature. Between the two gauges I have an electric fuel pump priming switch (dead man switch) and a two-way signal lever switch for the turn signal. Behind this plate I have a tiny Radio Shack buzzer that reminds me when I have the turn signals working. On occasion, when I need to give things an original look, I have the plate mounted to the dash lip with a couple of wing nuts which I can quickly remove and set the entire plate assembly up and behind the dash out of view. Other than the gauges and wiring I probably don't have more than $10 invested.
Tom
flatheadfan is offline   Reply With Quote
Old 03-03-2014, 07:39 PM   #7
john in illinois
john in illinois's Avatar
Thanks Mr Texas. Another idea for my roadster.
John
john in illinois is offline   Reply With Quote
Old 03-03-2014, 07:59 PM   #8
TJ
TJ's Avatar
American Auto Wire also sells a toggle turn switch. You can buy it from Summit Racing.
Old 03-04-2014, 11:22 AM   #9
Mike
Mike's Avatar
Thank you all
Mike
Old 03-04-2014, 12:53 PM   #10
Matt in Alameda
Also Mike, you can put the front turn signal lites inside the horns, behind the mesh. I made my kit to do this, thinking I was real clever and then I saw a 20 year old catalog that had a kit for it. Today Bob Drake sells a kit for it. It is a very clean and neat installation.....Matt in Alameda
Matt in Alameda is offline   Reply With Quote
