Old 04-09-2021, 04:01 PM   #1
Dennis Pereira
Dennis Pereira's Avatar
Default What are you working on?
today I'm working on a 28 - 29 gas tank just cleaning it up and a little sanding. I think I'm going to sandblast and prime there's little to no work left except paint . Also a photo test this the tank I'm replacing too many repaired bullet holes and its been lined I just don't trust it . But it looks good .
Dennis in Kelsey ca
Dennis Pereira is offline   Reply With Quote
Old 04-09-2021, 06:05 PM   #2
mercman from oz
mercman from oz's Avatar
Default Re: What are you working on?
Keep up the good work.
Old 04-09-2021, 06:22 PM   #3
Jack Shaft
A six pack
Old 04-09-2021, 06:56 PM   #4
Dennis Pereira
Feels like I'm going backward on this project but when you find better parts you need to act . My new old tank
Dennis in Kelsey ca
Old 04-09-2021, 08:22 PM   #5
mercman from oz
Am glad that you were able to locate a better Gas Tank for your Model A Coupe.
Old 04-09-2021, 09:09 PM   #6
Jack Shaft
Dennis you're close,what do you need?
Old 04-09-2021, 09:44 PM   #7
Dennis Pereira
Just time I have a lot of projects around the place .
Dennis in Kelsey ca
Old 04-09-2021, 11:06 PM   #8
700rpm
700rpm's Avatar
Finally found an original RH tail light bracket in NZ. It arrived last week. Spent a little time gathering wires, clips, hole drill and such in preparation for installation on my Tudor.
An interesting discovery: I have always been told that the repro RH tail light brackets for post-1929 are incorrect. But comparing this original to a repro from Mike’s, I can’t find any significant difference. I’ll still use the original on my Tudor because I am only the second owner and in every case since buying the car in 1961 I have used only original parts whenever feasible and possible. But I can say that if you’re thinking about adding a RH tail light (and you should be) don’t disregard the repro. They’re very good, at least from Mike’s.
Ray Horton, Portland, OR
Old 04-10-2021, 01:33 AM   #9
updraught
updraught's Avatar
A six pack
A man after my own heart
updraught is offline   Reply With Quote
Old 04-10-2021, 08:11 AM   #10
1930artdeco
1930artdeco's Avatar
Running board mats for my car.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 04-10-2021, 08:21 AM   #11
Jack Shaft
I'm not cutting my six pack, I'm adding to it with a six pack
File Type: jpeg ci-modelo-especial-440cbc07250fd500.jpeg (12.0 KB, 10 views)
Old 04-10-2021, 08:23 AM   #12
Jack Shaft
Time? you find any of that ill pay top dollar..
Old 04-10-2021, 09:09 AM   #13
al's28/33
al's28/33's Avatar
My third gear is difficult trying to engage, a trip to my mechanic is in the near future.....
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 04-10-2021, 09:47 AM   #14
Lefthander1930
Lefthander1930's Avatar
When I Got my Victoria There was a tail light bracket that came with it, it had a R stamp on the back. Thought I was Lucky Maybe. The old saying measure twice & cut once rule came into effect. Took every measurement you could take about three or four times, Taped the bracket to the fender still didn't look right. With both brackets in hand & on the work bench this is what I found. The R bracket was shorter the the left, also the mounting face to the tail light was a different angle. The R bracket was new & from where I don't know. Mine came out good & I'm happy. I check eBay & Craigs list & seen pictures of some installs & you be the judge.
Lefthander1930 is offline   Reply With Quote
Old 04-10-2021, 11:33 AM   #15
700rpm
700rpm's Avatar
I’ve checked the NZ RH bracket against an original LH and they are the same length. Even so, I expect some challenges.
Old 04-10-2021, 11:45 PM   #16
updraught
updraught's Avatar
Won't last long once they put the wall up.
