Old 03-18-2021, 11:08 PM   #1
aandkt
Default Where can I get a 1936 spare tire mount gasket/Pad
Where can I get a1936 Ford Cabriolet spare tire mount gasket/Pad?
THANKS
aandkt is offline   Reply With Quote
Old 03-19-2021, 12:16 AM   #2
koates
Default Re: Where can I get a 1936 spare tire mount gasket/Pad
I dont believe these were ever made or fitted to original cars back in their day. The only ones I ever saw were for the 33 and 34 Fords which were newly produced in modern times but not made now. I have searched the original 1936 Ford parts factory catalogue for you but they are not listed. I suggest you purchase some 1/16" flat rubber sheeting at your local parts store or rubber store and make your own pad to the shape of the spare wheel mount casting or otherwise make some round rubber washers to go on each mount bolt between the rear panel and the spare mount. Regards, Kevin.
koates is offline   Reply With Quote
Old 06-09-2021, 03:24 PM   #3
aandkt
Sounds like a plan.
Thanks
Old 06-09-2021, 06:30 PM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
On one of my original '35 tudor slant back sedans I had ~ 1/32" thick fiber washers located between the back of painted body and the cast spare tire mount, at each of the three bolts that held the tire mount in place. I bought this car from the original owner and I'm sure it had not been taken apart before I dismantled it.
John
Old 06-09-2021, 06:55 PM   #5
DavidG
DavidG's Avatar
Insulating washers were used when the spare wheel served as the radio antenna, although that was normally on the open car body types.
Old 06-10-2021, 05:53 PM   #6
aandkt
Thanks to all. Washers it is.
