06-17-2019, 09:37 AM | #21 |
Re: sleeved wheel cylinders
Speedway lists them as: " All new castings with corrosion resistant SS sleeves.....".
06-17-2019, 10:01 AM | #22 |
[QUOTE=Frank Miller;1768423 If it was a loose fit then you certainly would have fluid leaking behind the sleeve. I thought of machining a groove with a lock ring to prevent this but a properly pressed in sleeve should not have this problem. At least I would not think it would.[/QUOTE]
Both sides showed signs of leakage on the small side of the wheel cyl. Its the large side that blew out on the left side of the car. I too thought about adding some kind of locking ring, but think best to just go with cyl that are not sleeved. |
06-17-2019, 11:29 AM | #23 |
Barnfind08 on this forum has NOS cylinders.
John
Welcome each day |
06-17-2019, 12:50 PM | #24 |
If you want to try and save them, there are retaining compounds made by Loctite that work on interference and slip fits.
https://www.henkel-adhesives.com/us/...compounds.html |
