Old 04-18-2019, 01:58 AM   #1
Alaska Jim
Alaska Jim's Avatar
Default 41 Ford speedometer cable
can any of you fellows tell me the size and thread pitch for the end of the speedometer cable that screws onto the back of the speedometer on a 1941 Ford passenger car ? any help would be appreciated. Thank You.-----Jim
Alaska Jim is offline   Reply With Quote
Old 04-18-2019, 09:02 AM   #2
corvette8n
corvette8n's Avatar
Default Re: 41 Ford speedometer cable
The biggest die I have is 5/8x18 and the back of the speedo looks larger and finer than that, if I can figure out another way to measure, I'll get back to you.
This is from a spare '41 dash I have out.
Old 04-18-2019, 01:55 PM   #3
Alaska Jim
Alaska Jim's Avatar
The reason I ask, is I have a '41dash that I am modifying to fit a '29 roadster, and am using a t-5 5sp. trans with the electric speedometer sensor. I am considering using a product called Cable x that converts the electronic signal to a cable drive, but I need to know the type and size of the end of the cable where it screw into the back of the speedometer. the '41 passenger car speedometer I have looks like it may be 3/4 ,but I have no idea what the thread pitch is, and was hoping some one here would know. corvette8n, Thank you for your input. any other help, comments, or suggestions would be appreciated. by the way, the roadster was a pile of rust, passed over by all the restorers and headed to the scrap yard when I found it, and the '41 dash and gauges were the same. I figured building a hot rod out of the stuff is better than seeing the stuff ending up being a new Subaru. Thanks for any help.---- Jim
Old 04-18-2019, 09:46 PM   #4
fordor41
fordor41's Avatar
It appears from the Lokar site that Ford, '48 and earlier, has 3/4-20 male thread (Lokar #SP-1506U)
fordor41 is offline   Reply With Quote
Old 04-18-2019, 11:04 PM   #5
Alaska Jim
Alaska Jim's Avatar
fordor41, Thank you for that information. I had not thought to look at any of the aftermarket sites to see if there may be a listing. learn something new every day. Thank you.--- Jim
