03-03-2019, 07:24 PM | #21 |
Re: supercharged y-block carb on e-pay
It would be very difficult, if not impossible to build a clone or phony version of this carburetor, because of the unique base.
Sal |
03-03-2019, 08:19 PM | #22 | |
Was the SC H4000 base unique in shape or was it just sealed to prevent pressure blow-by through the throttle shafts?
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
03-03-2019, 08:24 PM | #23 |
Can I ask the source of your info? I have both SERVICE and PARTS info that says differently. Just want to know the actual fact(s).
03-03-2019, 09:45 PM | #24 |
"I stand corrected and apologize. The two photos below show the location of the CARB ASSY DATE"
"Was the SC H4000 base unique in shape or was it just sealed to prevent pressure blow-by through the throttle shafts? " Kultulz, no apology needed here. I was just pointing out that they did have codes, and the location. The SC carb had added thickness to the casting on the left rear side. Unlike all others. Also, the pictures you posted are of one of the carbs I did. (not an SC carb). Sal " |
03-04-2019, 12:59 PM | #25 |
Thanks for all this discussion, guys. In my early days with birds and salvage yard trips, we ran across all kinds of blowers and e type configs. At the time in the late 60's all those things were pretty mysterious and puzzling to deal with, not having a good knowledge base. I had seveeral e tpe setups and several blowers setups but never could accumulate all the needed parts for a good blower setup for my bird. It seems like all we ever saw were these REALLY basketcase set ups. However even though it was all sold off, traded, or abandoned in those days-I wish I had kept every bit of the junk. No internet. No Manual, No aftermarket catalogs yet. just heresay mostly.
Dad was a corporate pilot and flew all over the country. Whenever he would have downtime in anytown, USA he would head to the local FORD dealership and buy as many tbird specific items as he could haul back on the plane. Fun times, lots of interesting parts for dirt cheap. Although we didn't know it then. |
03-04-2019, 01:04 PM | #26 |
AHHH KT - you just love to keep me on my toes ! As discussed the parts used had to be "homologated" for use by any of the race teams. Meaning they had to be listed as an availiable production part . The Phase 1 parts are listed. They were snuck in for the race boys thru the back door as "Police Interceptor" parts. Lord knows the Cops had to chase those moonshining bad guys so not only were preformance parts listed but items such as beefier brakes and suspension items were also included in the homologation parts list. I will admit that most of my knowledge originally comes from the owners of these machines but for verification as requested Ford"s "1949 - 1957 Police Interceptor" Parts list has the carb identified as B7A 9510-V. Using the trusty Master Cross Reference book to cross reference the B7A 9510-V it shows the "Known Part Number" stamped on the carb as EDB 9510 AA. Not yet mentioned is the fact that the AA carbs were subjected to a higher boost pressure used for the race boys. Meaning that there are a few differences inside the AA carb when compared to the lower boost pressures of the AB Phase 2 carbs. I too have seen the documentation that you have stating that the units were interchangeable. Is there an actual table that states that AA were Phase 1 and AB Phase 2 applied ? - the answer at this time is not that I am aware of. However I will take Ford"s Police Interceptor parts list verifieing the AA use on the earliest known vehicles along with the knowledgable owners who make the claim. Oldmics |
03-04-2019, 07:28 PM | #27 |
Well, the EBAY auction ended and no bids or "buy it now" on the supercharger carburetor.
If it gets re-listed, I'm curious if the price will be lower. I'm sure there were a ton of people following this one. Sal |
03-04-2019, 08:10 PM | #28 |
03-05-2019, 02:01 AM | #29 | |
SELLER'S DESCRIPTION ON EVIL-BAY -
The references I have found describes the assembly of the engines (PHASE 1) in JAN 57. Then they would have to go to an assembly plant. So how was a D/F FORD bought with the CARB in question in DEC 56? The carb(s) in question were (are) LISTED in 49/59 MPC FINAL ISSUE. I also have FORD info as stating the -AA was BIRD ASSY and -AB was FORD ASSY - PHASE 1. PHASE 2 used -AB on either assembly and -AA was later replaced by -AB. Either CARB -AA / -AB could have not been used on any assy other than SC as the CARB CALIB was unique for boost. The only way it could have been used on a POLICE VEHICLE is if the POLICE PACKAGE was ordered with the SC engine (PHASE 2). I would post all of this but my scanner is on hiatus (and I have my good clothes on and can't get them dirty fighting). Now, I need to know if the ASSY DATE CODE was stamped on the fuel bowl cover (9524) on the raised portion please ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 03-05-2019 at 04:45 AM. |
03-05-2019, 04:24 AM | #30 |
Does anyone have the shown 1957 SC Manual?
If so, does it give PHASE 1 and/or 2 info, especially relating to carburetion? EDIT - Ah, I see the board is up to it's old tricks with Ill's ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 03-05-2019 at 05:46 PM. Reason: ADD ILL |
03-05-2019, 02:45 PM | #31 |
I asked the EBAY seller what the date code is. He said "621". That is the first week of Feb. 1956. Doesn't make sense. Sounds way too early, but maybe they did build them that early. I kind of doubt it though.
My gutt feeling is that the carb has been worked on somewhere along the line and the bowl cover was changed. Doesn't help answer any questions, but does add to the confusion. Sal |
03-05-2019, 03:14 PM | #32 |
This link is to an interesting article from Amos Minter about the Phase 1 D/F birds.
Says all 15 cars were built on Jan. 25th, 1957. Hand built at Dearborn Assembly Plant. Sal https://www.amosminter.com/1957_White_Supercharge_1.php |
03-05-2019, 05:42 PM | #33 | |
THANX! for that effort/info Sal. What it does in invalidate the claim it is 100% factory correct (IMO).
03-05-2019, 06:00 PM | #34 |
KULTULZ,
Yes, I would say it's not 100% correct parts because I took another look at the pictures. The bowl covers were changed for different venting in the late 1956 model year, and all carbs forward of that had the revised bowl covers. The carb in the EBAY auction has the old style bowl cover. All of the supercharger carbs I've seen had the revised new bowl covers. Not a big deal to replace, since all 4000 model teapot carbs for Ford had the same bowl cover for the end of the '56 model year. Fairly common to find. Sal |
03-05-2019, 06:03 PM | #35 |
I also told the EBAY seller what was up with the bowl cover. I doubt he will edit the auction though.
Sal |
03-05-2019, 07:10 PM | #36 | |
And now this-
SOURCE- This article is from the Standard Guide to American Muscle Cars by John Gunnell (Krause Publications) Who's to say? I doubt if all facts will come to light as most have been lost or forgotten. And then you have the naysayers that add their spin. There has to be HOLLEY documentation somewhere that will answer when the blow-thru carbs were first offered. I also believe there was factory racing and racing team fabrications and they were separate.
03-05-2019, 07:35 PM | #37 | |
And here is yet another song and dance-
SOURCE- www.supercars.net/blog/1957-ford-thunderbird-df-code-phase/ So when you see a supposed D/F CODE BIRD with full trim, it is not a survivor or claimed restoration but a resto-mod.
03-06-2019, 12:12 PM | #38 |
Think I may give up for now. The '57 Bird that Amos Minter is claiming to be one of the 15 D/F birds is loaded with options like power windows and seat, skirts and full wheel covers.
Not exactly a stripped radio and heater delete car as described it should be. Gets pretty confusing to me, since Amos is the premier T-Bird restorer in the country. Sal |
03-06-2019, 12:43 PM | #39 |
Yeah, this subject for the rich kids. I never got even close to a version. It goes to show what all types of facts and myths are floating.
Why would FOMOCO build a fully optioned race car? I doubt they made a profit on the PHASE 1 cars, just trying to make it NASCAR legal.
03-07-2019, 07:57 AM | #40 | |
SOURCE- https://www.hemmings.com/magazine/mu...o/1797835.html __________________________________________________ ______________________ So, I had been dating my future wife for about a month and decided I would try and take it a little further. I asked if she had ever been to a DRIVE-IN MOVIE and she said no, but would like to see one … As we sat there, I decided to make my move. We sparked and spooned for a while and I asked if she wanted to get in the back seat. She whispered no, so I decided to keep working on her. I could see that she was responding to my bar-stool Casanova techniques. Again, I softly asked, and she whispered no. I asked her why and she said she wanted to stay up front with me …
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 03-07-2019 at 08:33 AM. |
