Old 03-26-2015, 10:42 AM   #1
Cartravel
Default Spark plug clearance
Finally fired up our flathead and ran it for the 20 minute cam break in. I was doing some checks before firing it up again and noticed about half of the spark plugs are being kissed by the valves. I had checked this with clay before installation, but obviously did not do a very good job. I have Offy 450 heads and cam with about .350 net lift. I installed BP6HS plugs (1/2" reach). I machined the head around the plug holes so the thread lengths would match. The thread length is only 1/16" longer than the the H10s, but to the tip of the electrode they are 3/16" longer. I have read BP6LS plugs recommended, but they are only 1/16" shorter than the BP6HS. The P means projected insulator type. The local auto parts store has B6L plugs. Would that be a better choice? I have a preference for NGK plugs.
Larry Young
Cartravel is offline   Reply With Quote
Old 03-26-2015, 12:01 PM   #2
Pete
Pete's Avatar
Default Re: Spark plug clearance
You don't need projected nose plugs. Try the B6L's.
Another alternative is to use 1/8" solid copper plug washers. This will probably move the nose back far enough to clear.
The solid washers transfer heat better also.
Old 03-26-2015, 07:22 PM   #3
BillM
BillM's Avatar
I f you want a projected tip plug there is a 7/16" reach for 1954 Fords that are about .605" from the washer to the end of the tip: Champion RH18Y or Autolite 437. Also there is a 3/8" reach projected tip for 1970 Chev 5.0L V8 that is about .530" long: Autolite 85. The NGK plugs listed for these applications weren't projected tip plugs though. I have about the same head and cam lift situation as you and am using the Autolite 85's presently.
My web page:
http://myplace.frontier.com/~wgmumaw/
BillM is offline   Reply With Quote
Old 03-26-2015, 09:47 PM   #4
Kahuna
Kahuna's Avatar
Or, just double gasket/washer the plugs
Kahuna is offline   Reply With Quote
Old 03-27-2015, 03:02 AM   #5
JWL
In come cases I have used 3/8" reach plugs. However I like to chamfer out the inside, exposed, threads before I install the heads.
There are plug indexing kits with a variety of plug washer thicknesses from which to add to your existing washers. I do not like to use multiple washers because it makes the plug much easier to foul but it can be an acceptable "get by" solution.
JWL is offline   Reply With Quote
Old 03-27-2015, 11:07 AM   #6
KGS
KGS's Avatar
Who sells spark plug washers separately?
KGS is offline   Reply With Quote
Thread Tools
Display Modes
