Old 08-13-2013, 08:22 PM   #1
oldguy41
Unhappy Timing cover fill of oil and timing off
Went to time my 1931 S/W today and found oil in timing cover, cam problem ?
oldguy41 is offline   Reply With Quote
Old 08-13-2013, 08:24 PM   #2
Bob C
Default Re: Timing cover fill of oil and timing off
Can you explain a little more what happened.
Bob
Old 08-13-2013, 08:37 PM   #3
oldguy41
When I went to start my S/W I had to pull my lever down all the way to start. SO I went to retime the system. When I removed the timing pin I found oil on the end on pin. This car had not be started in a year. I think that the gaskets are all shot. Not a good engine guy.
Old 08-13-2013, 08:43 PM   #4
kelley's restoration
kelley's restoration's Avatar
i would check to see if your oil pan is full of water
that would raise the oil up into that area
tk
anyone need some Model A restoration work done in Illinois? shoot me an email for pics and information
[email protected]
kelley's restoration is offline   Reply With Quote
Old 08-13-2013, 10:13 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
Oil enters the valve train from the pump, splashes around there a bit, goes down tubes to the bearings and also flows over a raised portion in the front of the engine to the timing gear.
If your timing pin has oil and the oil is not flowing out the hole with the engine off, it seems to me to be working fine.
Old 08-13-2013, 10:22 PM   #6
700rpm
700rpm's Avatar
Which lever did you have to pull down all the way?
Ray Horton, Portland, OR
Old 08-16-2013, 05:38 PM   #7
oldguy41
Thank You Mike V., I just have a timing problem, it jumps time, I think the Cam is not engaging the the upper shaft fully, it has a new cam and screw @. The cam is moving both forward and backward, I hit the upper shaft with a tool to rough it up but may need to replace.
Old 08-16-2013, 05:47 PM   #8
J Franklin
J Franklin's Avatar
You lost me!
Old 08-16-2013, 06:59 PM   #9
sidhartha
sidhartha's Avatar
By upper shaft, are referring to the distributor shaft?
sidhartha is offline   Reply With Quote
Old 08-16-2013, 07:08 PM   #10
oldguy41
Yes, the Snyders Book calls it upper shaft, but you are correct
Old 08-16-2013, 07:10 PM   #11
Bob C
If you have to much backlash you need to check the distributor drive
gear and the slots in the shaft for ware.
Bob
Old 08-16-2013, 07:14 PM   #12
oldguy41
Thank you , I will pull the side cover off and take a look, The shaft is a two piece and the lower piece was not replaced when build in 1973.
