Old 03-16-2021, 06:48 AM   #1
Dave1931Pickup
Default Need Help Identifying This Carburetor
What model of Zenith is this? What is the thing protruding down from where the Main Jet would be installed? It has a knurled end on it which appears to be removable as a separate item from the thing hanging down which also appears to be removable. Looking down the throat the Main Jet and the Cap Jet are visible.
Thanks for the help.
Dave1931Pickup is offline   Reply With Quote
Old 03-16-2021, 08:18 AM   #2
1crosscut
1crosscut's Avatar
Default Re: Need Help Identifying This Carburetor
Farmer fix?
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 03-16-2021, 08:25 AM   #3
Jack Shaft
No GAV...I'd guess its for a constant speed governed industrial engine. Zenith's multiple jet design became obsolete rather quickly, emulsion tube carburetors ( marvel schebler style) were cheaper to build and performed better..
Old 03-16-2021, 11:21 AM   #4
Jim Brierley
Simple answer, it's an old, dirty carb!
Old 03-16-2021, 12:15 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
It does look to have adjustable main jet
Old 03-16-2021, 12:28 PM   #6
redmodelt
redmodelt's Avatar
I would rule out combine. The ones I have seen had an air balance tube on one side so oil bath filter could be used.
Old 03-16-2021, 10:21 PM   #7
CWPASADENA
CWPASADENA's Avatar
Yes,
Adjustable main jet.
I have seen this before but not for a very many years.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 03-17-2021, 12:20 AM   #8
redmodelt
redmodelt's Avatar
I have seen a couple of stock Model A Zeniths that had an aftermarket adjustable jet installed.
Old 03-17-2021, 11:53 AM   #9
DHZIEMAN
Looked around on ebay, and I may have gotten close but no model on the carb but rather what one that resembles your pictures. The one I found was off a COE GMC 248! Not sure if the helps or more confusion.
DHZIEMAN is offline   Reply With Quote
Old 03-18-2021, 05:35 AM   #10
Wick
Wick's Avatar
Could be a racing accessory carb. Stamped zenith to comply with rules.
A tractor carburetor is more likely.
Wick is offline   Reply With Quote
Old 03-18-2021, 07:28 AM   #11
Benson
Benson's Avatar
When you look down into throat are the main and cap jet staggered or are they lined up with each other?
Old 03-18-2021, 09:19 PM   #12
Dave1931Pickup
They are staggered. Thanks everyone for all your help.
Old 03-18-2021, 11:35 PM   #13
Benson
Benson's Avatar
OK thanks.
At first I thought the carb might be a very early prototype 27 but it does not have the bosses for double venturi pin or pins and you confirmed it does have the staggered Cap and Main jets of the single venturi versions which happened after the Stromberg law suit.
Very strange that GAV is missing though.
Old 03-19-2021, 12:36 AM   #14
redmodelt
redmodelt's Avatar
Maybe not if it ran at a set speed on a stationary engine.
