08-18-2020, 10:39 AM | #1 |
Paint prep
What do you clean car with before painting, after sanding?
08-18-2020, 10:58 AM | #2 |
Re: Paint prep
A Dupont product called PrepSol.
08-18-2020, 12:31 PM | #3 |
Re: Paint prep
Do they even make prepsol anymore? I use a product called 'final clean'. It was made by Dupont, but the last gallon I bought had a different manufacturers name. Everything else was the same, including the name and product no. I dont know if it is creative accounting on Duponts part or what.
I put the product in a spray bottle, and spray directly to the metal, then wipe down with a clean white cloth. When the cloth stays white after a wipe down I know its clean enough. I dont dip into the gallon can for fear of contaminating the product. May be a bit of overkill but it seems to work for me. |
08-18-2020, 01:19 PM | #4 |
Re: Paint prep
Valspar makes a no voc prep solution,works good
08-18-2020, 01:31 PM | #5 |
Re: Paint prep
What brand & line of paint are you spraying??
08-19-2020, 04:41 AM | #6 |
Re: Paint prep
08-19-2020, 06:03 AM | #7 |
Re: Paint prep
Surely your Wanda dealer has a recommended pre cleaner product?
08-19-2020, 08:29 AM | #8 |
Re: Paint prep
I "seem" to be having good luck with a rag, saturated in lacquer thinner. Maybe someone will tell me what I'm doing wrong (I'm no painter) and what and why it will happen. Then I wipe it off with a tack rag. It seems to be working.
Terry |
08-19-2020, 08:38 AM | #9 |
Re: Paint prep
the idea is to get any grease and dust off prior to paint, thinner and a tack rag should do it as the soap and water they sell out here.
08-19-2020, 01:22 PM | #10 |
Re: Paint prep
Wipe down as above, but I also add a small amount of TSP with my bucket of water while wet sanding.
08-19-2020, 01:37 PM | #11 |
Re: Paint prep
The only right way to do it is use some kind of solvent, preferably enamel reducer. Then you tack it off with a tack cloth. That is the way I was taught and I have never had any problems.
"The more things change, the more they stay the same." |
08-19-2020, 02:25 PM | #12 |
Re: Paint prep
Their recommendation below ....
08-19-2020, 02:37 PM | #13 |
Re: Paint prep
Most of my model A's were covered in surface rust to start with . If it still has paint on it, the first thing that I do is wash the vehicle with soap and water . If the surface has had wax applied in the past, sanding doesn't completely remove the wax . Wax causes fish eyes in the new paint that will be applied . I then solvent wash after the soap and water wash . . Never wipe with a tack rag over a wet surface , especially a solvent wet surface . A tack rag is coated with a sticky substance that picks up whatever dust that remains on the mostly clean dry sanded surface , before spraying on the paint . Most if not all paint suppliers have a special solvent to use before applying the paint . It doesn't matter if the solvent is prep sol , final wash or whatever the brand calls it . I have often used enamel reducer as a final wash before applying the paint . Never use lacquer thinner as a final wash because it can loosen and smear the old finish and make a mess .
08-19-2020, 02:56 PM | #14 |
Re: Paint prep
I use PPG DX330 Wax and Grease Remover. never had any issues when painting
08-19-2020, 03:35 PM | #15 |
Re: Paint prep
I was always told to never use lacquer thinner or enamel reducer to wipe down before paint. Don't remember why, but if you do, you still need to clean with a wax and grease remover.
08-20-2020, 05:20 AM | #16 |
Re: Paint prep
Thanks I'll check with dealer
08-20-2020, 05:37 AM | #17 |
Re: Paint prep
Like Todd j I also use PPG DX330 with no problems. Never use a tack rag that you would use on wood work. After all my work in getting a panel ready, I used a tag rag and you could see all the places where the waxy substance was left. The paint would not stick and it pulled away leaving little holes to the primer all over the place! As I recall I re-sanded the panel and wiped down three times with PPG DX330 using two rags, one wet and the other dry for the final clean. Change the rags often. I buy a bag of 250 lint free rags from Home Depot @ $12.00.
08-20-2020, 07:53 AM | #18 | |
Re: Paint prep
08-20-2020, 06:57 PM | #19 |
Re: Paint prep
NEVER use lacquer thinner. Even though it melts stuff off the surface it leaves residue and can cause fisheyes. A good name brand of automotive wax and grease remover will be fine. Make sure you wipe it on the panel wet and take a dry lint free wipe to dry it after. You can get disposable wipes at the auto paint store and you can get more than one use out of them if you’re careful not to tear them up. Blow it and tack it and you should be good to go.
