10-02-2021, 01:10 PM | #1 |
1942 Ford Super Deluxe Door Handle Escutcheon
I have a 1942 Ford Super Deluxe that my family has owned since new. The escutcheon around the front door handle broke, and I am looking for a replacement. My problem is that all the replacements that I have been able to find are 1/8" or more thicker than the original part.
It is impossible to get the pin into the hole, even with the spring compressed all the way. Unfortunately this is not a matter of installation technique. I would like to continue to use the original door handles, but that may not be an option. Any advice or assistance would be very much appreciated. Thank you. Thank you. |
10-02-2021, 04:33 PM | #2 |
Re: 1942 Ford Super Deluxe Door Handle Escutcheon
1942 Ford Inside Handles. Does this picture show the part that you are chasing? |
10-02-2021, 05:35 PM | #3 |
The reproduction escutcheons are about 1/8" thicker. I had an even harder job replacing them on my '46 Station Wagon because the interior panel is wood and has no give at all. What I did is a fair amount of work but this is what I did. If you look at the back of the escutcheon there are 4 holes. If you bend back the four tabs that hold the stainless to the plastic you can get it apart. I then removed about 1/8" from the stainless with a die grinder and files and shorten the tabs an equal amount and re-assemble. It makes the pin easy to install.
10-02-2021, 10:38 PM | #4 |
or look on e-bay for some OEM's.
10-03-2021, 09:04 AM | #5 |
Thank you for the replies above. I have been looking for a similar one on Ebay for 3 years and have seen nothing so far (duh). Unfortunately mine are quite different from those available from Dennis Carpenter et al. They are chrome, and I may have to change all the doors to match the one that failed. It looks like I will have to work on my metal fabrication skills. I will try to post a picture.
Thank you again for the input. Mercman from OZ's restoration looks superb. I have a long way to go to get to that standard! |
10-03-2021, 09:13 AM | #6 |
10-03-2021, 10:24 AM | #7 |
Bob Drake has the "universal" chrome escutcheon that fits '32 to '48, PN, B-7022618-U but again, it's a reproduction and might have to be modified to fit.
10-03-2021, 10:40 AM | #8 |
Did you try it without the spring? On my 39 there was no way I could get pin in with spring. Aftermarket escutcheons. Without the spring they are fine and was still a battle to get the pin in.
10-03-2021, 10:46 AM | #9 |
10-03-2021, 01:57 PM | #10 |
On my '46 the spring is wound so it will compress into itself, so it's not an issue. It is the stainless ring that is too fat. If you match it up with a stock stainless ring, the reproduction is about .100, (apx. 7/64") thicker. I'm not familiar with the '39 dimensions as Mark posted.
10-10-2021, 08:04 AM | #11 |
I just got back from HERSHEY and if you still need the escutcheons I saw that Mark's Ford Parts, 607-729-1693 has N.O.S. escutcheons.
