10-14-2021, 05:20 PM | #1 |
brand new water pump
I just got a new leak less water pump today. I got the old one off and transferred the fan blade to the new pump with the key installed but it only freely turns for a 3/4 of a turn by hand then it binds up. I inspected the inner pulley and it is scratched. It is hitting the housing and I noticed the housing is not true all around. If I just install the new pump will that problem go away by itself or is it a major concern?
10-14-2021, 05:55 PM | #2 |
Re: brand new water pump
not that uncommon, just grind a little on the pump housing where it is rubbing.
10-14-2021, 07:33 PM | #3 |
