10-11-2020, 10:52 PM | #21 |
Re: Found Very Concerning Issue
If you don't have a torque wrench, BUY ONE. They're not that expensive, and anyone who is into cars (old or new) should have one.
10-12-2020, 12:34 AM | #22 | |
You need hardened washers under the nuts not just flat washer they MUST be hardened to function correctly.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 |
10-12-2020, 01:47 AM | #23 |
Your 1936 Ford when new was fitted with aluminium cylinder heads (not painted) and had rather thick steel washers under the head nuts. During the life of many cars the aluminium heads gave trouble and were replaced by cast iron heads (painted) which were more durable. The cast iron heads did not require the washers under the nuts. Torque specs for aluminium heads and cast iron heads are different. Regards, Kevin.
10-12-2020, 06:29 AM | #24 |
I had a lot more that a tablespoon and the condensation could be related to the hot air heater and all its tubes collecting water. Its probably not related to the coolant in the spark plug hole. But then again as the coolant burns off it could make steam and as it goes down the exhaust pipe turns back to water. I fell upon that by accident by pulling a plug to get the number off it. It just so happen the one plug I pulled was the one with the coolant in it. So what ever the case the heads need to come off. The one nut I took off did not come off easy all the way to the end.
This is not the original engine and I'm just going by what the original owner told me. I put a magnet on the heads this morning and it sticks, so they can not be aluminum. I counted 21 studs. |
10-12-2020, 06:48 AM | #25 |
Do it the right way - don’t use the breaker bar; buy or rent a torque wrench and tighten each bolt in the recommended sequence.
No job’s done ‘til it’s all done |
10-12-2020, 06:53 AM | #26 |
10-12-2020, 07:04 AM | #27 |
No worries I found the info on Van Pelts web site. I assume this is an 85hp right? Says 50-60 ft lbs for cast iron heads
10-12-2020, 07:21 AM | #28 |
Since the torquing process actually stretches the bolt, some like to initially torque (in the correct sequence) to just under the specifications, and then follow with a second torque after a brief interval to full spec so as to ensure a more accurate tightening.
10-12-2020, 12:21 PM | #29 |
10-12-2020, 12:50 PM | #30 | |
Agee, you need to own one....1/2 inch and calibrated in foot/pounds....most are but I managed to find one that only measured in Newton....not very useful to me |
10-12-2020, 01:03 PM | #31 |
Thanks, I have one on it way from Amazon now, once I get my exhaust all back together I will move on to this issue.
10-12-2020, 01:36 PM | #32 |
You guys probably will cringe at this but, I tried to free a few of the nuts and I'm afraid I will break a stud. One stud above the hole with the anti freeze in it is rusty and does not feel good when I try to loosen it with the breaker bar. My gut is the stud is leaking. Is every one against trying an engine block sealer? The leak seems to be very minor and probably only when its cold. I do need to do some more experiments.
10-12-2020, 01:52 PM | #33 |
You said >"So this 36 I just bought has a rebuilt engine with about 3K miles on it." And you said > "I started it up and noticed when it was cool lots of black water or moisture coming out of the exhaust, once it warmed up it seems to clear up and go away."
Given what you said, I wouldn't hesitate to try a block sealer....
10-12-2020, 01:52 PM | #34 |
The RTV (or other silicone-based sealer) will only work on clean / dry surfaces; apply liberal amounts of PB blast and let soak. If needed, get some modeling wax or clay to create a small dam / reservoir around the frozen stud to ensure a good soak. Do not force under any circumstances.
10-12-2020, 02:02 PM | #35 |
Delete
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN Last edited by Lanny; 10-13-2020 at 11:54 AM. |
10-12-2020, 02:23 PM | #36 | |
10-12-2020, 02:28 PM | #37 |
I watched the video I'm not to sure about the fiber aspect of this product. I certainty need to consider the old radiator I don't want to clog up. I do run the car without a thermostat like the previous owner, so clogging that will not be an issue.
10-12-2020, 02:30 PM | #38 |
10-12-2020, 02:34 PM | #39 |
I have used this product with great success > https://www.kseal.com/products/k-seal
No draining or flushing of cooling system with this product - will mix with anti freeze....
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 10-12-2020 at 02:46 PM. |
10-12-2020, 02:43 PM | #40 | |
Water Glass is an old flathead standby. "Liquid glass" (sodium silicate) is added to the system through the radiator, and allowed to circulate. Sodium silicate is suspended in the coolant until it reaches the cylinder head. At 100–105°C (212-221°F), sodium silicate loses water molecules to form a glass seal with a remelt temperature above 810°C (1,490°F) Last edited by JSeery; 10-12-2020 at 02:48 PM. |
