07-30-2015, 03:10 PM | #1 |
molassess and crank shafts
Last week I got rid of 2700# of scrap. I did keep some merc cranks that I would like to save. Pretty rusty although the bearings surfaces are not to bad. Question is if I soak these cranks in molasses and water for 3 or 4 days to remove the rust, will this harm the bearing surfaces. All the cranks need to be reground. Thanks Bill
07-30-2015, 04:28 PM | #2 |
Re: molassess and crank shafts
I would NOT put them in molasses,this will attack the steel,any high grade steel will be badly affected by the molasses,this will take the carbon out of the steel.
Lawrie |
07-30-2015, 04:37 PM | #3 |
I would agree with Lawrie. Some friends took an Arnold Bristol block and put it in a Molasses mixture and probably ruined the block. The metal is now very flaky. Dave/Green Bay
07-30-2015, 05:45 PM | #4 |
I have done a half dozen blocks and they came out great.
07-30-2015, 06:02 PM | #5 |
You have to monitor it....couple days in molasses or vinegar can attack the surface rust without destorying the remaining good metal. Couple weeks and you might be in for trouble.
07-30-2015, 07:04 PM | #6 |
07-30-2015, 07:09 PM | #7 |
In this case baking is out of the question. Nearest oven I know of is 800 miles away.
07-30-2015, 07:42 PM | #8 |
Bill Glass bead ? is that an option ?
07-30-2015, 07:44 PM | #9 |
maybe if I can lift it into the beader. Never thought of that. Mask off the bearing surfaces. Hmmmm
07-30-2015, 07:57 PM | #10 |
You didn't say you had a blaster....duct tape the journals and glass bead the rest of it. Then have the journals ground or polished.
07-30-2015, 08:18 PM | #11 |
If you have the scratch, you should try EvapoRust. That stuff is fabulous; eats up rust and doesn't touch anything else. I did the Grille extensions/Parking light units on my '51, and while it removed all of the rust from ther backsides, it didn't touch the black paint in the grooves. About $90 for 5 gallons, though.
07-30-2015, 09:57 PM | #12 |
LOL I have the scratch but not the itch.
07-31-2015, 08:13 AM | #13 |
Just glass bead em, you won't hurt a thing, don't forget to remove the sludge plugs in the cranks. I run a steel brush with a drill in those sludge holes. Walt
07-31-2015, 08:56 AM | #14 |
Soda blast them
R |
07-31-2015, 10:18 AM | #15 | |
800 miles is like driving to Minneapolis or Denver. There will most definitely be one between you and there.
Mike Wanted: - '32-34 Open Cab Pickup (RPU) parts and documents/articles/info - ARDUN parts |
07-31-2015, 10:34 AM | #16 |
The only oven I have found is in Creston British Colombia. Just over 1000 km each way. I have used it when passing through and it was great.
07-31-2015, 11:28 AM | #17 |
I would think hard about using glass bead. If those beads can find a way into the engine, all hell will break loose.
Alan |
07-31-2015, 12:55 PM | #18 |
Man oh man, I am with you on this one. I would not take the chance.
07-31-2015, 01:07 PM | #19 |
Whats the difference with the beads over the leftovers from the grinding wheel when you grind it later...
Have to be cleaned up before assembly anyhow. For small narrow passages like a carb i prefer sodablasting that disolves when washing it. |
07-31-2015, 02:34 PM | #20 |
well I cleaned 3 of them with glass beads. Will give them a thorough cleaning tomorrow before the hot tank.
