Old 12-29-2012, 07:39 PM   #1
Bruce_MO
Default '32 Gas tank fuel pick-up unit repair
My '32 would not start, and I assumed the fuel pick-up unit was plugged with rust. Unfortuntely, I discovered that it had corroded in half after I pulled the gas tank. I had heard of this happening to others, but the last time I had the tank out (8-10 years ago), it was in good shape.
I can get all the parts out...is it possible to rebuild these things and replace all the tubing between the cups and the "bell"? I'd like to get the hydrostatic gauge working again.
I've started looking for another, but I assume that they might be a bit gard to come by.
Thanks in advance for any ideas you might have.
Bruce_MO is offline   Reply With Quote
Old 12-30-2012, 12:09 PM   #2
G.M.
Default Re: '32 Gas tank fuel pick-up unit repair
Bruce you can repair any part of the sender. Consider it as plumbing fixture it is not some hokus/pokus mysterious part.It is only brass and copper parts with holes in it. The dome on the bottom and the size of the holes need to be like they were originaly. Sounds like a victim of the new gas. I have a new one that's not for sale but could give you dimentions if needed.Cars and P/U are the same, commercals with the tank under the seat are differant. G.M.
www.fordcollector.com
Old 12-30-2012, 06:44 PM   #3
Bruce_MO
If you have the overall length from the underside of the mounting flange to the very bottom of the fuel pick-up tube, that will help me. I've ordered up a bunch of brass tubing and sheet stock. The pieces I recovered out of the bottom of the tank basically disintegrated when I bead blasted them, so I'm starting from scratch about 1" below the lower cup.
Thanks.
Old 12-30-2012, 07:16 PM   #4
Pat/Ohio
Pat/Ohio's Avatar
Bruce, These become available every once in a while on epay. I have purchased a one or two over the past 3 or 4 years. Hemmings also has them listed. Might check with Baxter Ford Parts. Good luck, Pat
Pat/Ohio is offline   Reply With Quote
Old 12-31-2012, 10:34 AM   #5
G.M.
Bruce I'll take a few pictures and post them with some measurements. G.M.
Old 12-31-2012, 03:01 PM   #6
G.M.
Bruce I found 2 1932 senders, one used and one new. I took some pictures of both.
1--air hole under bottom dome .046
2--small tube ID .080
3--vent hole near pinched end .125
I hope this will help you. I see the bent air tubes on the bottom
vary a little. One set comes in straight and the other set is
out at a slight angle. G.M.
