Old 10-12-2020, 03:31 PM   #21
cvicky
cvicky's Avatar
Default Re: vibration
yes new timing chain and gears
i set timing by vacuum engine runs best but light shows 20-25
ill do piston stop when i get a chance
i have another intake just have to make time
cvicky is offline   Reply With Quote
Old 10-12-2020, 09:23 PM   #22
KULTULZ
KULTULZ's Avatar
Post Re: vibration
The FYB timing setup is different from other engines. Did you install according to correct SHOP MANUAL?
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 10-13-2020, 12:13 PM   #23
rotorwrench
rotorwrench's Avatar
The timing chain gear alignment procedure for the y-block is like no other engine. It's easy to get the cam out of time if it's not just right.
Another FYI is the ignition systems were originally mated to the type of carburetor. You mention a 1959 distributor. What type of carb are you running with that?
Old 10-13-2020, 01:54 PM   #24
dmsfrr
dmsfrr's Avatar
Since the unusual Y-block timing chain & gear alignment has been mentioned twice, here's a picture...
dmsfrr is offline   Reply With Quote
