05-20-2020, 01:08 PM | #1 |
57 y block
I have a block with CECK
6015 A 5 stamped at the back beside distributor and a 2 barel carb what does all that mean |
05-20-2020, 02:06 PM | #2 |
Re: 57 y block
" CECK 292 cu in Cast in Canada. Export block. Used in Canada, Australia ect "
from this link... http://ford-y-block.com/Block%20identification.htm |
05-20-2020, 06:48 PM | #3 |
Re: 57 y block
they also used it to make 312
05-20-2020, 09:33 PM | #4 |
Re: 57 y block
If it's an original 312 the rear flange of the crankshaft will have a dot on it
and the main bearing caps will have an "ECZ" prefix, not EBU. |
05-21-2020, 06:16 AM | #5 |
Re: 57 y block
ive had several of these engines.the 56 had the dot but not 57.you can spot them as they didnt cut out the recess where the dot goes.the only cut out is the half moon.they did have ecz caps.
05-21-2020, 01:57 PM | #6 | |
Re: 57 y block
Both of the (Cleveland foundry) '57 312 engines in my garage have the dot. (if that means very much) How to ID a 312, two links.... http://ford-y-block.com/identify312.htm http://ford-y-block.com/crankshaftid.htm The 312 crank also has a slightly different overall appearance. Photos at the 2nd link above. In some cases having ECZ main caps will be more definitive than a potentially missing dot, if you don't have the means to measure the bore & stroke. That said... it is possible to machine the mains of a 312 crankshaft down to fit into a 292 block and use the stock EBU main caps and rear seal. But it's a very one-off sort of thing. Last edited by dmsfrr; 05-21-2020 at 08:38 PM. |
05-21-2020, 03:15 PM | #7 |
Re: 57 y block
Yes, people think a 312 is always a 312. I suppose it is, but the 312s were different, as highlighted above. Seems like the draft tube was different, and a water jacket drain was different too. People say 312 to me all the time, but the 312 Thunderbird Special was a different crank, and block all together, as I recall. When true car guys ask about a 312, I think they are asking about the 312 Thunderbird Special. Guess that's just me.
05-21-2020, 03:52 PM | #8 | |
Re: 57 y block
http://ford-y-block.com/Block%20identification.htm http://ford-y-block.com/crankshaftid.htm A full-sized Ford with a Y-block engine could have either a Cleveland or Dearborn cast block. (There were also foundries in Canada and Brazil which were a possibility.) The '55/'57 T-birds only used blocks cast in Cleveland, But, there were no blocks or crankshafts used exclusively for the '55/'57 T-Birds. As a marketing tool the Birds might get engine upgrades sooner but they were also optional on the full-sized cars. There are several bolt-on pieces that make a complete Thunderbird engine different. Most were just to accommodate the lower & set-back position in a narrower engine compartment with a lower hood. Rear sump oil pan, timing cover, dual exhaust manifolds, tach drive dist, valley pan, air cleaner, road draft tube .... Excepting the E and F code versions, the "Thunderbird" option package on a full-sized car was usually a 4bbl carb, dual exhaust, a couple other performance parts and emblems or decals. . Last edited by dmsfrr; 05-21-2020 at 07:30 PM. Reason: add links |
05-21-2020, 07:15 PM | #9 |
Re: 57 y block
im still talking about the ceck block and crank.these cranks were cast in canada and the 57 312 didnt have a dot.
05-21-2020, 07:53 PM | #10 | |
Re: 57 y block
When talking about Ford parts and cars there are two words I've learned not to use: always & never. For anything made in Canada it goes double. The original post by cvicky didn't specifically mention a crankshaft, only the block number & 2bbl carb. Since the engine block ID chart on the Mummert website doesn't list the possibility of a CECK block being a 312, their information could just be out of date. as is this one... http://www.yblockguy.com/identify_y-block.htm Given the relatively low numbers of Canadian vs US engines this wouldn't be surprising. . Last edited by dmsfrr; 05-21-2020 at 09:19 PM. |
05-22-2020, 05:57 AM | #11 |
Re: 57 y block
john hasnt updated that in way over 10 years since he put it up as far as i know.
