Old 11-26-2019, 08:15 PM   #1
Mulletwagon
Mulletwagon's Avatar
Default U Joint Service
After a few hours of "cotter pin hell" finally pulled the rear axle. Discovered much play in the "rivet style" U Joint. What is the proper lube schedule for the U Joint and how is it serviced ? Is it just a matter of pumping max grease into the joint housing through the grease fitting ?
Mulletwagon is offline   Reply With Quote
Old 11-26-2019, 08:37 PM   #2
ryanheacox
ryanheacox's Avatar
Default Re: U Joint Service
First off, that much play in that style U joint means a replacement is needed. Once that is done, put everything back together and with the speedometer gear off pump in grease until it starts pushing out of that hole. Reinstall the Speedo drive and have fun.
ryanheacox is offline   Reply With Quote
Old 11-26-2019, 08:48 PM   #3
J Franklin
J Franklin's Avatar
Try and find a semi-fluid grease as solid grease can be thrown off and leave the joint dry if it is not added often.
Old 11-26-2019, 08:59 PM   #4
chrs1961815
chrs1961815's Avatar
How much play is normal?
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 11-26-2019, 09:02 PM   #5
TMarsh
I did much research and used john deere cornhead grease available at deere dealers.
TMarsh is offline   Reply With Quote
Old 11-26-2019, 09:18 PM   #6
J Franklin
J Franklin's Avatar
You should have no noticeable radial play.
Old 11-27-2019, 12:48 AM   #7
Bill G
Bill G's Avatar
Get a pneumatic grease gun or you are in for a lot of hand pumping. I pumped and pumped and pumped, and then borrowed one and finally got the grease out the speedo hole. I think Harbor Freight sells a pneumatic.
Bill G is offline   Reply With Quote
Old 11-27-2019, 07:38 AM   #8
Patrick L.
Patrick L.'s Avatar
U-joint play, There will be a lot of axial[ side to side] play. There should no radial [ rotational] play.
Lube, That housing doesn't hold much grease. There is info above on how to fill the shell. It shouldn't take much more than one tube. If too much grease is pumped in it will find its way past the rear bearing slinger and into the transmission. Transmission oil will leak into the shell/ housing and mix with the grease.
Old 11-27-2019, 09:26 AM   #9
Kurt in NJ
Kurt in NJ's Avatar
Look close at the rivits to see if they are loose, if loose look for later style, they were used up till 48
Old 11-27-2019, 02:57 PM   #10
J Franklin
J Franklin's Avatar
That is how Ford manufactured the A, but some trans. rebuilders use sealed rear bearings so if you are not sure, u-joint lube service now and then might be a good thing.
Old 11-27-2019, 03:53 PM   #11
40 Deluxe
Did you get the kind for high speed gearboxes, or the one for low speed gearboxes? John Deere sells both. So if we want to do it right, we can use the low speed cornhead grease in the steering box, and the high speed grease in the u-joint.
Old 11-27-2019, 04:01 PM   #12
40 Deluxe
If cornhead grease is hard to find, or no John Deere dealers nearby, use CV joint grease. Every parts store sells tubes of the stuff, and it is semi-fluid just like cornhead grease. Ever change a CV boot on a front wheel drive vehicle? The boot can be torn open with grease flung all over the suspension, and the joint itself will still have grease in it (unless it ran that way for thousands of miles).
Old 11-28-2019, 07:27 AM   #13
Patrick L.
Patrick L.'s Avatar
Yup.
Old 11-29-2019, 12:39 AM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
Maybe I'm thinking in the wrong terms, but I always think of radial play as the side to side movement, which is how a Model A U joint works.
I think of rotational play as the slop you can feel while holding one end of the u-joint and trying to turn the other end back and forth. This is where you want no play.
Old 11-29-2019, 01:24 AM   #15
J Franklin
J Franklin's Avatar
Maybe just semantics, but we both know play in the U-joint is not wanted.
